Full Version: Vemiri Peralae Wheels
Lexus Owners Club > General Lexus Forums > Wheels & Tyres
gothika
Hi
thinking of getting some vemiri peralae wheels 19 x 8 does anyone know of any handling problems for aftermarket alloys? sorry if this has been asked before i'm a newbie.
company say they do fit and i've seen a pic of a IS200 with them on but not a IS 250. i love the wheels and have managed to track some down for £1150 for 4 (no tyres), they are £356 each on performance alloys, if anyone knows of other wheels for the IS 250 or can get the vemiri peralae's cheaper than £1150 I would be glad for the information.
Gothika.
http://www.vemiri.com/home.php
Tango
QUOTE
Mine are not OEM's...here, and extra pics in the Gallery.
gothika
Hi all
looking for some help/ advice for fitting alloys to my IS 250.
I have been looking for some aftermarket alloys and have finally settled on some vemiri peralae http://www.vemiri.com/home.php.
I was just wondering, will the 19 x 8 rims be ok?
and I was thinking of putting 245 35 19 on the rear and 225 35 19 on the front.
Also if and when I have done this, would it be wise to get the geometry checked out by WIM?
Thanks G
Tango
QUOTE(gothika @ May 28 2007, 05:11 PM) [snapback]441260[/snapback]
QUOTE(Tango @ May 28 2007, 05:06 PM) [snapback]441259[/snapback]
QUOTE(gothika @ May 28 2007, 04:29 PM) [snapback]441247[/snapback]
Hi all
Thanks G
yeah sorry about that
finding my way around site (being newbie)and found the wheels topic and thought more members would see it and reply.
So why don't you follow on from your previous post if you have more questions? It keeps everything together so peeps can follow it smile.gif http://www.lexusownersclub.co.uk/forum/ind...mp;#entry440903
As far as I know you're the only other UK LOC member with a second generation IS who wants to fit non OEM wheels, so not surprised there were no other answers.
Your IS has staggered rim widths, the OEM (original equipment manufacturer) fitted are 8" wide on the front and 8.5"' wide on the rear. Are you proposing to replace with 8" wide x 19" diameter all round? The only IS250 to have the same widths all round is the AWD (all wheeel drive) version available in the US, but not UK.
To give you an idea, my new set up is:
Front 19x8.5 rims with +38mm offset. Tyre size 225/35ZR19
Rear 19x9.5 rims with +42mm offset. Tyre size 275/30/ZR19
I don't have any rubbing with this set up, but the front really needs 235/35 as the 225 looks stretched.
Whatever you want to do this will be useful http://www.dakota-truck.net/TIRECALC/tirecalc.html
Re. the geometry check, get it checked by WIM when you fit new rims and tyres (don't forget he's moving addesses) ....and even if you don't I'd suggest you get it checked anyway because the Lexus factory settings are not the optimum. msn-wink.gif
gothika
Thanks Tango
Yes I was proposing to put 19 x 8 on all round but won't after reading your info.
Thats p**sed on my bonfire mate Vemiri's are only available in 19 x 8
19 x 9.5 and 19 x 11.
Back to the drawing board I suppose
Thanks for the info Tango very helpful.
yemgi
QUOTE(gothika @ May 28 2007, 05:39 PM) [snapback]441299[/snapback]
There is no problem so. Get 19x8 for the front and 19x9.5 for the rear
gothika
Thanks Vemgi
If that'll work then great.
sorry don't know a deal about wheels.
Tango
QUOTE(gothika @ May 28 2007, 06:39 PM) [snapback]441299[/snapback]
Thanks Tango
Do you know what the offsets are on the 19x8 and the 19x9.5 Vemiri's? You could use similar offset to mine on 9.5" rears and keep the same offset as the OEM fronts for the 19x8" Vemiri'swith near max width tyre for the 8" rim..
gothika
Hi Tango
I looked at your settings and thought I would email Vemiri to check and they sent me this email back.
Hello Glen,
I have been checking the widths on this vehicle and as I already thought the maximum you can go on 19” is 8.5 and no more and therefore the 9.5 x 19” will not work on this vehicle. The offset is quiet surprising to the old one because, the old IS200 would list and offset of 35-45, but the new IS250 list anything from offset 30-40,
I guess it’s because of the bigger arches it has compared to the old IS200 which has quiet narrow arches.
So to fit the Vemiri Peralae wheel will not be a problem at all. If you do decide to go for them, if it’s not too much trouble would it be possible to send some photos?
Any way I will leave this with you and let you decide what you would like to do.
And then I emailed Performance alloys and they replied:
Hi
Thank you for your enquiry.
No problem! We can do 8x19 et35 and 9.5x19 et42
Your set up works! which one of these experts should I listen to, main supplier, who is much cheaper or performance alloys.
whoever said pimpin aint easy was dead right.
Monster-Mat
id go with the main supplier, at the end of the day, they are cheaper, but there also easier to pin down if its not quite right
Tango
QUOTE(gothika @ May 29 2007, 12:29 PM) [snapback]441497[/snapback]
Hi Tango
Hello Glen,
I have been checking the widths on this vehicle and as I already thought the maximum you can go on 19" is 8.5 and no more and therefore the 9.5 x 19" will not work on this vehicle. The offset is quiet surprising to the old one because, the old IS200 would list and offset of 35-45, but the new IS250 list anything from offset 30-40,
I guess it's because of the bigger arches it has compared to the old IS200 which has quiet narrow arches.
So to fit the Vemiri Peralae wheel will not be a problem at all. If you do decide to go for them, if it's not too much trouble would it be possible to send some photos?
Hi
Well Vermiri certainly don't know what they're talking about, unless of course they're just considering the fronts as any wider than 8.5J will definitely not clear the arches under lock. Are you sure they know the second generation IS has staggered widths?
In the USA my set up is very common, and quite a few have gone 10" on the rear. 20" diameter rims have also been fitted to 250 & 350's.
If you need confirmation on my set up send a pm to Tony Bones @ WIM. Tony has been monitoring all things geometry and tyre wear with my vehicle. The new set-up is excellent, I wouldn't go back to the OEM rims or suspension settings.
