QUOTE(ProLex-UK @ May 31 2007, 12:29 PM) [snapback]442046[/snapback]
congratulations on getting one.....most underated car !
on lack of power check all the intercooler piping as it can come loose and that looses ooomph
what colour is the car ?
on the mods you list they all seem sensible. The TOM's ecu is good but its exopensive and you have to send yours to japan for them to modify it......tis about £800/£1000 all in. Good thing about it is it removes the 155 mph limiter...bad thing is it expects 100 octane fuel
I've seen two customers cars with it already fitted BTW so you may want to check
Oh and welcome to the club !
Cheers mate,you guys seem helpful here
Yeah the car does seem underated!I know the capabilties with that engine block,i just want to do it as cheap as poss.Whats the best place to go to install all these mods,any recommended garages?
I think i'll give the TOMS ecu a miss then,wont be able to run 100ron all the time,i usually use optimax 98RON.Do i have to get an aftermarket ecu or is there any so called - piggy back ecu available?
Oh yeah and any info on the wheels etc?
btw the car is a metallic blue,a few little dings and scratches,nothing that cant be sorted
QUOTE(skeet94 @ May 31 2007, 01:43 PM) [snapback]442063[/snapback]
Welcome to the club!!
I agree VERY under-rated car - everybody expects it to be some grandad car...little do they know
With regards to your mod list...here's my opinion
Denso Iridium IK24 spark plugs - Good choice!!
HKS cambelt (if required) - Not required...I'd much rather go and pick up a GReddy or Power Enterprise Super Timing Belt just to be safe.
FMIC (is ARC any good?) - Arc is one of the top dogs out there, but if you can try and find a GReddy 3-row for the same price.
Replacing cats? - Just go and do a full turbo-back exhaust system - I'd see Dave for a quality piece at a nice price
Uprated fuel pump (walbro) - You could use the Walbro, or you can rewire the existing pump with thicker guage wire to give it the recommended voltage - either way ... a necessity at the power levels you're looking at.
HKS Super SQV BOV or Blitz blow off valve? - Do you like a LOUD chirp or a smooth wooosh...? Also not a necessity if the stocker is good.
Front and rear strut braces - Highly recommended - I suggest you pick up the TRD Front Brace as it is a SOLID piece unless you're looking to go with EDFC for the Tein Suspension then pick up the Tein Braces or even the Cusco braces. Also see if you can pick up TRD Race Sways along with TOMS Underbracing.
Uprated discs and pads - prolex grooved discs and Mintex pads (any good?) - If anything see if you can upgrade to the UK/US Spec Supra 4 pot calipers - that along with stock discs and pads will give you all the braking power you would need at your power levels.
Blitz or HKS Boost controller (will i need a fuel cut defencer?) - If you go with one of the below ECU's you wouldn't need a FCD, I'd personally go and pick up a MINE's ECU for £550-600 with increased timing, programmed to run on 98octane fuel, all limiters along with speed, boost, fuel removed and rev limit increased to 7500rpm.
TOMS ecu or MINES or BLITZ - I'd say Mine's as it's cheaper and easier to get ahold of - the TOMS you're mostly paying for the brand
Hope that helps.
Cheers mate,good to meet you all.
Thanx for that buddy,looks like you know your stuff!Noticed you have already done quite a bit to ur Aristo,is it running fine etc,what sort of boost you running?
One question....who's Dave?
lol
Where can i pick up a MINE's ECU?
With the mods mentioned what sort of power gains am i looking at?
Any recommended garages?
QUOTE(chips229 @ May 31 2007, 02:48 PM) [snapback]442073[/snapback]
Hi and Welcome to LOC
Good Luck with the mods.
Thanx chips,i just dont want to f*** up if you know what i mean!Want to take care of this thing,cant believe how good these cars are!
