scooby_si
May 31 2007, 06:58 PM
As it says on the tin what do i need to be looking for for new wheels for LS400 & any other info on what other models of lexus or makes of car share the same stats?
Ta
Si
lutonmatt
May 31 2007, 07:15 PM
the pcd is 5x114.3
dont know what the offset is
but i do know that is200 wheel dont fit as the offset is to small
T7RY B
May 31 2007, 08:52 PM
PCD for all Lexus models is 114.3 I am pretty sure that the offset for the LS is 50.
I like the MAZDA RX8 wheels which apparently fit straight on with no modification.
Pic here of a members car with RX8 rims fitted
Ebay RX8 alloys
scooby_si
Jun 1 2007, 05:23 PM
crap i just sold 3 sets of RX7 wheels......
Si
Rob
Jun 12 2007, 04:44 AM
is200 wheels do fit - few members on here have done it
scooby_si
Jun 12 2007, 06:37 AM
ok so we now have conflicting infobut that would be good as there seems to be much more choice on the IS200 wheels at least on ebay etc
So anyone cofnirm or deny?
Ta
Si
T7RY B
Jun 12 2007, 11:59 AM
Si, check this post out. Lexus alloys on all models are interchangeable. Just that in some cases you may need spacer depending on the wheel size. i.e. if it is an 18" wheel being fitted to a OEM 16" fitment.
PCD Post on LOC
murphy jim
Jun 12 2007, 12:26 PM
QUOTE(T7RY B @ Jun 12 2007, 12:59 PM) [snapback]444933[/snapback]
PCD Post on LOCNOPE CHART ONLY COVERS LS400 FROM 91 - 94 NO POST 1994 INFO AT ALL
T7RY B
Jun 12 2007, 01:00 PM
94 on and the LS430 are the same PCD and Offsets
Also Aftermarket Alloys fitment guide link
fitment guide Lexus
murphy jim
Jun 12 2007, 07:56 PM
QUOTE(T7RY B @ Jun 12 2007, 02:00 PM) [snapback]444941[/snapback]
fitment guide Lexusnope ..no entry on link for ls430
T7RY B
Jun 12 2007, 09:08 PM
Nope ?????
Click on LS430 it then goes to the next page and tells you
LS430 pcd Offset etc.
Make - Lexus Model - LS 430 Year - 00> PCD - 5x114 Offset - 38 to 45 Bore - 60.1
Recommended fitments, 18" 2454518 19" 2454019 20" 2453520.
If package tyre is different from our recommendations, click to upgrade or remove tyres.
Results may show a 4 or 5 stud picture, ignore this as results are listed by fitment. Tyre calculator.
lutonmatt
Jun 13 2007, 06:36 PM
QUOTE
Ta
Si
sorry the is200 wheels do fit but have to have about 10-12mm spacers then you can see that they have spacers and look bad but they do fit
scooby_si
Jun 15 2007, 03:15 PM
cheers for all that.
Will need to look for wheels soon, well may as well, as will need a new set of boots for MOT anyways.
Question mode round 29, what are the standard tyre sizes on 16" wheels as i had a spare set in the boot when i bought car but noticed they're not the same as currently on.......
I'll have a look later.
Si
murphy jim
Jun 24 2007, 09:02 AM
QUOTE(scooby_si @ Jun 15 2007, 04:15 PM) [snapback]445872[/snapback]
Si
Hi Scooby,
Think standrad is 225/55 ... did you get your newwheels or tyres yet ?
I to am looking. I have a series 4 1999 ls400 and had a set sent which didnt fit so am wary of offset issue.
Ian R
Jun 25 2007, 01:45 PM
I have a '98 mk4 LS400 and have fitted 10 spoke 17" IS250 wheels without any issues.
Ian
scooby_si
Jun 25 2007, 08:08 PM
not bought any yet, i still have crap set, but very light & good for track days which i'll probably use for getting thru MOT & as my cash flows sorts out look for a blign set. Still focusing on gettign the bugger running right before i look at the cosmetic side too much.....
Cheers for info so far all usefull stuff
Si
scooby_si
Jul 16 2007, 09:56 PM
so lets see if i have it right, IS200 has offset of 50? so anything less than that should easily fit (if i recall correctly that smaller number means it sticks out more & thus clears brakes easier?) on a 5x114 pcd wheel generally speaking?
ta
Si
scooby_si
Jul 16 2007, 10:02 PM
or is it 38 or more as i dunno some prats have labeled IS200 wheels on ebay as 38 offset & another as 50 so i'm still none the wiser & wana go wheel shopping
Si
garethr
Jul 17 2007, 07:54 AM
The series 20 LS (UCF20 '94 on) has bigger 4-pot front brake calipers which need more clearance. That's probably why there's confusion about which wheels fit.
scooby_si
Jul 18 2007, 08:57 PM
So i'm looking at a set of 8j 18" offset40 wheels which i'm thinkign should fit, any thoughts?
Would 225 40ZR18 be the size of tyre i'd want to keep sameish size?
Si
murphy jim
Jul 25 2007, 02:31 PM
QUOTE(scooby_si @ Jul 18 2007, 09:57 PM) [snapback]454719[/snapback]
Si
Any joy ? I am finding it difficult to locate a supplier for 17" I understand th eoffset is 38 - 42 dependiing on wheel design ..didi you find anything yet ...if so any photos?
Oracle
Aug 2 2007, 08:35 AM
I need to get new tyres for the ls400 fairly soon, should I stump for new alloys at the same time?
If I stay with the stock alloys whats it the best tyre for the car?
click here.
