In response to a question in another thread, and after a very long weekend installing a complete new system to the car, I thought I would pass along a little gem which I was pleased I found.
Getting the power cable through into the cabin is a pain, but I found a way to utilise the existing grommet that holds the rest of the cabling, as follows;
1. Remove the Battery and the clamp/base etc on which it sits. This will leave you with a nice area to work in, as per the following pic (click to blow it up).
2. Remove the glove compartment, via the two clips holding in the hinges.
3. Rotate the grommet holding the power cables anti-clockwise. This will take a little brute force and ignorance, but not too much. Make sure you hold the cables going through it as you do so, they have very little slack so you don't want to risk stretching and breaking something valuable.
A small (5mm-ish) hole will be visible. This is currently sealed inside.
4. Get a HSS drillbit (purely because they are sharper than other types) lube it up with some vaseline, and force it throught that hole. Again, a bit of brute force is required, but you must be careful to not somehow punch into the power cables.
It'll take a bit of wiggling and rotation of the bit, but eventually the rubber seal inside will give way.
5. Get yer power cable, lube up the tip with a tiny dab Vaseline or similar, and just ram in through the hole you have now created. Try not to snigger at the back.
Here's an image of the final product:
I've used 4 AWG guage cable for my power system, as I have two amps to run. I'm not here to recommend what size you use as this will be purely dependant on the power supply required for the amps you have, but I can say that the seal that this then creates with this thickness of cable gives a really tight seal. I am pretty sure a step down to 8 AWG will also be a tight fit, but anything more or less thick will be an issue.
I thought this is an easy and safer method than drilling through the bulkhead or cutting the grommet. The seal is so tight around the cable, I didn't bother using liquid gasket or similar to gum it up, although if you are getting water in that area, you're already in trouble as that's where your battery is (!).
I used 6m of cable to get it through to the boot, and this was just right. Any less than that, and I think you'll be struggling. Do not forget to put a fuse just after the battery terminal. I cannot stress that enough. The fuse should be rated to suit the cable, not the amps. Other FAQ's should resolve this.
Hope this helps! Any questions, just post 'em on this thread.
