QUOTE(Pewe @ Jun 9 2008, 07:19 PM)
I recently replaced a front wheel bearing - and all appeared well.
Suddenly the other day I experienced violent vibration if I traveled over 60mph, and also noticed it at 40mph up a steep hill.
Thought it might be the wheel bearing coming loose - but on jacking up the car I found the front wheel was bound tight - and subsequently found that it was a binding piston on the caliper.
Earlier in this post 'osteo66' was hoping to post some simple instructions for repairing the caliper, and a link for the supplier, but obviously never got round to finding time to do it.
Can anyone recommend a suitable supplier of repair kits, and possibly any links to anywhere I might find some useful instructions before I start the task of repairing the caliper.
Also, do you think it is worth doing both front calipers at the same time as eMJay suggested that the seizing is a common problem.
Hi Pewe,
Oops...completely forgot
I've recently had the same symptoms re-occur and have found the second piston partially seized and the lower slide pin seized (see another thread).
Repairing the pistons and pins isn't difficult BUT should be done only if confident with mechanical work and brakes in particular - these are designed to stop you after all and if you are at all unsure get a professional to overhaul them for you. Better safe than sorry etc...
Having said all that I overhauled mine with a kit from brakeparts (google them) after advice from LOC members. This is how I did it.
Jack the car up and support safely (axle stands etc), remove wheel then loosen caliper bolts (you may need a spanner on the slide pins to stop them rotating). Depending on which piston seized I use a G clamp to hold the other one in and pump the seized one out by foot brake until almost free. I removed the top of the brake fluid reservoir and secured cling film over the top to form a vacuum. Undo the caliper brake hose bolt and detach pipe from caliper - wrap end of pipe in clean cloth and tape to prevent fluid loss. When caliper off I used pliers to gently tease the piston free, discard dust boot and fully clean the piston with scotchbrite (the green plastic kitchen cleaning/scouring pads). Fully inspect piston to ensure no corrosion or pitting in the sealing area, if there is I replace the piston. Scrupulously clean and dry the piston and place to one side. I then clean out the caliper and remove the piston seal gently with a small screwdriver being VERY careful that I don't scratch the inside diameter which may scrap the caliper. Clean out the groove of solidified brake fluid (I use a bent paper clip) until spotless. When everything is as clean as I can make it lube new seal with fresh brake fluid (this stuff is nasty, I wear protective gloves) and replace in caliper. Next is the tricky bit, I tried to put the new boot onto the piston first then lube piston and insert into caliper and also tried it the other way around, both of which are fiddly when you try to install clip that retains the boot into the caliper. I recently read another method (USA forums?) that advocates boot onto piston then push piston all the way into caliper to give room the fit boot retaining pin into caliper. Haven't tried this method personally. I had to BE VERY PATIENT here!! If another piston needs doing I use the same process which works for me. Sliding caliper pins are easy to replace (provided they are not seized!), make sure the right grease is used and the correct bushes go onto the individual pins - there are other posts about this and installing the gaiters. The brake caliper is then reinstalled using new copper brake pipe washers and all bolts torqued correctly. The difference was immediately noticeable. Brakes may need bleeding slightly.
I'm sorry if I've contravened site rules by describing my procedure and that it's a bit long/convoluted. Obviously this is my method and may not be the 'official' way of doing things therefore you use this info at your own risk, I accept no responsibility etc...and I reiterate if you are not comfortable with the job get a professional to do it for you.
I've probably missed something out, if I have ask away and I'll clarify. This isn't a job I particularly enjoyed but the results were worth it as was the cost saving!
Enjoy!!!
