CruzMissile
November 24, 2003, 11:31 pm
T/C isn't boy wonder since it will allow in certain situations to keep in control without the back end sliding out.
If, however, you turn in hard on a wet road surface, T/C on, and your back does break out, you'll need all the steering skills you have to keep it from spinning 180° SINCE YOU WILL LOOSE ACCELERATOR CONTROL due to the fact that that's just what the T/C does : it cuts the juice! NOT GOOD, in certain situations.
I prefer to drive with T/C on when I'm cruising and will not engage in hard turning.
Though I prefer to have T/C off if I would want it to be "possible" for the car to break out controllably since then you can manage the sliding by accelerator.
All this is quite difficult & tricky if you first start driving rwd cars. It would be nice to look for an large empty lot on a wet day to start experimenting with the different effects of turning and drifting, using T/C and without T/C.
I have always driven rwd cars and if you're in it for the sport and enjoyment of driving and don't see your car merely as a means of transportation, then you might find rwd the only way!
Greetz
