Last weekend, doing some electrics, (actually installing new towing electrics), car on ramps, ran a big thick cable from the battery to the boot to serve the 12S socket.
Finished them off, wife called me in as lunch was ready, I reached in and extracted the ignition key and went and ate.
Later, I decided to check out the fridge connection (OK the electrics are for towing a caravan...). Went out, inserted the ignition key and found that the ignition lock was jammed and would not turn. Half hour later still no joy but luckily I had got it to the ACC position so was able to easily pull the barrel out.
Long story a bit shorter, ordered a new one from Lexus, and left it. Went out to the car Sunday late on, - battery COMPLETELY flat.....
THE QUESTION
Anyone know if the ignition being left on ACC (with nothing obvious switched on like the radio or lights) would drain the battery, or have I screwed up the electrics in some way.
My new barrel has arrived and will go in tonight so I can test my electrics with the engine running (and get it off the ramps!!!)
Hoping someone has more of a clue than me!!!
Cheers
Dave
