QUOTE(GoldfingerLS @ Apr 23 2008, 10:48 PM)
Thanks Tango. 2 stage system it is then. Did the filters come with it when you ordered it from screwfix ? or which filters did you order separately ? I like the idea of having a fine filter in the 2nd housing.
If this works well, I would get one for the house aswell. The water areas in the kitchen and bathroom accumulate a lot of limescale very quickly. And not to mention that the clothes after going through the washing machine should feel softer as they are not saturated with minerals...........
Filter cartridges should come with the housings. The two stage has a sediment cartridge (which is only £2.99 to replace) and a polyphosphate cartridge (£19.99) that removes anything greater than 10 microns in size.
The manufacturer (Culligan) also do a 1 stage unit with a filter cartridge that removes sediment down to 5 microns and the cartridge is cheaper than the polyphosphate one at £9.99. I think it's designed to be hooked up to a single drinking water tap so the flowrate may be a bit restricted, but this 5 micron cartridge also fits the housing for the polyphosphate one so I thought I may give it a try.
I don't expect to have to renew a cartridge for a couple of years or more in the two stage unit just using it for garage use.
