waynejordan02
Sep 24 2007, 08:45 PM
im getting my hands on a supercharger for my is200 and need a few tips or descriptions to help me do this i have a freiind who is a merchanic but has never fitted one befor so any and as much help would be good please guys
thanks
wayne
Sep 24 2007, 09:05 PM
Well done mate, if you didn't live so far down south i could of come and given you a lift mate
Sep 24 2007, 09:15 PM
Ditto, LOL
waynejordan02
Sep 24 2007, 09:19 PM
no worrys guys any tips or description should be ok also on a scale of 1-10 how hard are they to fit or is the hardest part removing the bumper
thanks
wayne
Rob
Sep 24 2007, 09:21 PM
its about a 3 or a 4 at the most..
waynejordan02
Sep 24 2007, 09:29 PM
has anyone ever posted up how to install one
Sep 24 2007, 09:39 PM
Don't think so.
i found the hardest apart was getting the ecu cover off to solder in the ECU.
The only tip i can think of is get all the nuts in loosely on the cradle before you tighten any up.
Rob
Sep 24 2007, 10:12 PM
QUOTE(sparkystav @ Sep 24 2007, 11:39 PM)
Don't think so.
Good point! cake the ECU cover off then undo the nuts holding the ecu in place and have a look at the metal cover - check if u have security screws - they may well be 5 pointed torx style screws. Ithey are then u have to drill them out or make a slot in them to use a screwdriver or maybe ask someone at the lex garage to take the screws out for you.
YOU WILL NOT FIND THE SCREWDRIVER BIT IN THE SECURITY BIT SETS U CAN BUY IN THE SHOPS its a torx plus security bit if ur interested
Sep 24 2007, 10:17 PM
Don't they need to put on in a certain order ?
(the cradle nuts that is )
Rob
Sep 25 2007, 07:53 AM
the bolt holes on the cradle are not 100% accurate as the cradle is hand made - but its about 98% accurate, i found the bolt that goes into the block slightly out so for me it was best to install that one first
waynejordan02
Sep 25 2007, 11:55 AM
does anyone have the fitting instructions they could email me my email address is waynejordan02@aol.com.
thanks
wayne
Rob
Sep 25 2007, 12:00 PM
just email tte and they will send it to you
waynejordan02
Sep 25 2007, 02:45 PM
QUOTE(Rob @ Sep 25 2007, 01:00 PM)
do you know the site address
Rob
Sep 25 2007, 02:47 PM
QUOTE(waynejordan02 @ Sep 25 2007, 04:45 PM)
yes i do thanks!
just use the same email i gave u before for the stickers, Florian will sort you out with instructions
Sep 25 2007, 04:02 PM
QUOTE(waynejordan02 @ Sep 24 2007, 10:19 PM)
thanks
wayne
Pm'd you my number
Sep 25 2007, 04:09 PM
QUOTE(Rob @ Sep 24 2007, 10:21 PM)
WOW Rob, i know someone who took 2 hrs to take the rear bumper off the is200
Sep 25 2007, 04:48 PM
QUOTE(Rob @ Sep 24 2007, 11:12 PM)
Or maybe you will
Ebay LinkFound these the other day an promptly got myself a set,
A bit after the horse has bolted but may come in useful for the future.
Rob
Sep 25 2007, 05:06 PM
QUOTE(sparkystav @ Sep 25 2007, 06:48 PM)
Or maybe you will
thats a different shaped driver but i suppose it would just about fit... you might have to drill the hole out to a larger size tho
ebay link
Rob
Sep 25 2007, 05:10 PM
Or maybe you will
Sep 25 2007, 05:13 PM
well they arrived today and they Fit like a glove no problems at all.
Rob
Sep 25 2007, 05:29 PM
QUOTE(sparkystav @ Sep 25 2007, 07:13 PM)
ah well thats good then! might have to get myself some also - i found the same set for £9 but the robbing barstewards want £12 for post to here......
Jamie
Sep 25 2007, 05:41 PM
Would you have the link to that seller, Rob?
Jamie
Rob
Sep 25 2007, 05:50 PM
linkyhere u go
Jamie
Sep 25 2007, 06:01 PM
Legend, cheers amigo.
Jamie
Rob
Sep 25 2007, 06:05 PM
QUOTE(Jamie @ Sep 25 2007, 08:01 PM)
Jamie
any time mate..
click here.
