Rob
Sep 25 2007, 06:00 PM
Hi ,
as in the title for those that have bought an OBDII reader recently has anyone seen a function/option to read or plot on a graph the boost pressure??? - for those with a supercharger of course..
I want to see real time readings that can be logged for review at a later stage. Is it also possible to view the air/fuel ratio?
Sep 25 2007, 06:06 PM
Did you not have a look at that program i sent you?
Sep 25 2007, 06:11 PM
Whats the better software to get with these ???
Rob
Sep 25 2007, 06:19 PM
QUOTE(sparkystav @ Sep 25 2007, 08:06 PM)
no not yet just wondered if anyone knew straight away - but im opening the prog now.
Rob
Sep 25 2007, 07:29 PM
stav the prog wont open....
Sep 25 2007, 07:44 PM
Did you extract it, install it, then replaced the file with the cracked one from the other folder?
Rob
Sep 25 2007, 07:55 PM
yep ill try again tho
Sep 25 2007, 07:56 PM
K mate, works fine for me,
No one else has had any problems.
Let me know mate.
Rob
Sep 25 2007, 07:58 PM
tried it again and no joy - get an application error - does it only work with framework?
Sep 25 2007, 08:02 PM
Framework? sorry not sure what you mean.
Rob
Sep 25 2007, 08:11 PM
it asks if i want to install the optional microsoft .net framework - which i dont want to do
found out prog only woks with framework.... pity
Sep 25 2007, 08:19 PM
hmm can't remember that sorry.
Jamie
Sep 25 2007, 09:40 PM
Can you not install .NET, Rob, or are you restricted for some reason? (O/S etc...) I'm sure you're aware that .NET Framework 3 is a redistributable downloadable
here from Microsoft.
Jamie
Rob
Sep 26 2007, 07:34 AM
Is all sorted now, - i was reluctant to install framework beciaase last time it buggered up the comp and i had no end of problems, i took the chance and it seems to be working ok for now.
Sep 26 2007, 05:30 PM
Does it read what you want?
Rob
Sep 26 2007, 05:33 PM
i had a look thru and i believe so... ordered a reader yesterday and it was posted today so will have to wait and see but if def looks promising...... thanks! BTW!
Sep 26 2007, 05:44 PM
Not a problem squire.
click here.
