Full Version: Removed The Radiator - To Change Oil Cooler
Lexus Owners Club > Lexus Models > Lexus GS 300 / Lexus GS 250 / Lexus GS 430 / Lexus 450h / Lexus GS 460 Club
GSSPORT
Hi All,
I had to change my power steering oil cooler (old one corroded and leaked everywhere) and to do that I had to remove the radiator.
The question which I hope someone can help me with is:-
How can do I refill the cooling system without getting air locks? : :unsure:
I have had this problem before (with an old cavalier) and it caused all sorts of problems.
Any advice greatly appreciated
P.S: The car in question is MK2 GS300.
Many Thanx
mudzs
i did mine a few months back and put heater on hot and just filled her up whilst a friend reved car slightly .no aur locks at all
Einstein
Fill it slowly....
Start engine with filler cap off, and keep topping up... when the inlet pipe gets warm.. i.e. when the thermostat has opened, the level should drop a bit more, so top up again and put the cap back on..
allow to run for a while, go for a drive if you like, then check again when cold.
John
