Coup
November 4, 2007, 5:13 pm
When I press my heated seat, the heat heats up to a nice warm temp, after that it goes off and slowly cools down again, but then does not get warm again. If i press the button, within 5 minutes the seat has gone cold again and i'd have to turn it off and back on again.
Is this how it is meant to operate? More of a blast of heat than a regular temp?
Thanks.
Rob
November 4, 2007, 5:36 pm
yes it heats up then cools down after a while - when it drops down it will heat up again but usually only after about 20 mins but this all depends on the temperature
Rob
November 5, 2007, 3:47 pm
found out the seat warms to 45C then shuts off until the temp is below 25C then comes on again
Coup
November 5, 2007, 10:21 pm
[quote name='Rob' post='482851' date='Nov 5 2007, 03:47 PM']found out the seat warms to 45C then shuts off until the temp is below 25C then comes on again[/quote]
cheers for that. i'll test it out next time i go out.
sorted vti
November 10, 2007, 5:58 pm
yeah i thought it was a bit wierd at first! rather it just be hot all the time
