Hi, have had the following advisories on an MOT on my Mark 2 GS300 -
Offside front lower trailing arm rubber bush deteriorated
Nearside front lower trailing arm synthetic bush deteriorated
Nearside upper suspension arm has slight play in ball joint
I know the ball joint will be expensive as I believe the entire control arm has to be replaced, is it best to change both sides at the same time?
Also which parts do I need to replace the dodgy bushes?
There is sometimes a slight clonking noise at low speed, often when the car is cold, do you think this is likely to be coming from the faulty ball joint?
Thanks for your help.
