mubz
Dec 8 2007, 05:46 PM
I need a pair of track rod-ends for is200 year is 2000, i have been told the car cannot be tracked without them as they are bent and damaged? Any that has a pair PM please? thanks
rig-pig
Dec 8 2007, 07:47 PM
try a motor factors m8 T,R,E bent ????? how thay get bent ??? never seen this in all my time as a mech ????
ProLex-UK
Dec 8 2007, 09:11 PM
do u mean ball joints............i have a pair £100 all in
HOW HOW CAR U BEND BOTH TRACK ROD ENDS?? i suggest going to a different place to have the alignment done, because as i have found out a lot of places are just incompetent and say something is broken to cover thier faults
wheels-inmotion.co.uk
Dec 9 2007, 08:01 AM
Reads very odd?...... The steering arm may bend if the wheel impacts something very hard... It's unlikely both are bent and it's very unlikely both cast track-rod-ends are bent.
It would be wise to gain a second opinion before you buy any parts.
mubz
Dec 9 2007, 10:26 AM
Only driver side is bent but i was advise when changing the track rod ends best to change both sides as the person did manage to track one side! And as one of you had said when something is hit at an impact it can bend which in my case had happened! This is what is causing me a rough ride! thanks people
MacRS200
Dec 9 2007, 11:22 AM
As already said above get a second opinion, track rod ends don't bend, track rods do. If you have a bent track rod replacing the TRE won't fix it.
click here.
