Full Version: Mk2 Aristo Type Tail Lights
Lexus Owners Club > Lexus Models > Lexus GS 300 / Lexus GS 430 / Lexus 450h / Lexus GS 460
shake
I noticed in a window reflection that a brake light was out, what a pain to change! but easily done in 5mins.
i also noticed the top of the tail lights is actually just a blank plate! i was thinking of drilling a hole and adding another brake light.
then today i see a white mk2 with the tops of the tail lights lit on!!! is this a mod? or did lexus after 1999 actually use the space on top?
if so anyone know the part number for the harness?
P4UL T
Yes after 2001 there was a small facelift of the GS, the rear light clusters were changed to a more modern look.
These can be swapped with the older ones and yes you do have to do a small mod to the loom.
If you do a search you will find that a few members on here have done this and there are a few how to threads knocking around
HTH
Paul
