Full Version: Parking Sensor
Lexus Owners Club > Lexus Models > Lexus IS 250 / Lexus IS 220D / Lexus IS 250C
RobNorm
How often has your parking sensor malfunctioned due to it being frozen?
It's happened to me twice with the temp below -4.This morning it was -6 and put it into reverse and got a continuous tone which didn't clear until I put it into D.
I presume this is the parking sensor causing this?
Bazza
it is probably frost covering the sensor !
Ian M
Frost, or just the general accumulated muck on the back of the car this weather.
dazz32
QUOTE(RobNorm @ Dec 20 2007, 07:38 AM) *
as the others have said ...should be ok if you clean the sensors in the morning...its just they are covered in frost ,dirt etc..
oldcro
As already mentioned, did you take a few seconds to just look at the sensors and make sure they are clean?
RobNorm
It must have been a build up of frost on the rear sensors
Rillo
sensors are definitely affected by frost and by mud/road grime.
Geoffers
Yep. Technically they are doing their job if they are detecting frozen water...
Says in the Manual. (The first entry in fact):
"Certain vehicle conditions and the surrounding environment may effect the ability of the sensor to correctly detect obstacles. Particular instances where this may occur are listed below.
* There is dirt, snow or ice on the sensor."
Lol - just spotted this on CL too.
