CERWIN VEGA 15" Home Cinema subwoofer.
MODEL: CLSC-15S
Not to be confused with the clsc-15sx which is a more compact version and handles less power and nowhere near as good!!
This is one serious subwoofer. Guaranteed to shake the house if you want it too!!
It has a line level in and crossover to your front speakers or can be used as a standalone sub from your amp.
Do not be fooled by the 200w power rating as this goes extremely loud and very low..
It is made by legendary american speaker makers CERWIN VEGA with a reputation for bass!
I am only selling it as i am very lucky to have found another great sub and will be collecting this today!
It is fully boxed as new with all original packaging and manuals. Demo is possible if you.
There are no marks or scractches and is in MINT condition.
It can be used as a home cinema sub, can be connected direct to a TV, Computer, stereo system, in essence its connectivity is endless!
As its quiet heavy shipping i would suggets picking up or i might be able to drop off depending on location.
Delivery is possible but wont be cheap!
I paid £700 for this about a 18 months ago and still retails for around the £500 mark but t his particular model is very hard to get in the uk.
Yours for £300....
TECHNICAL SPECIFICATIONS:
200 watt (rms) (500w peak) active subwoofer
Continuously variable crossover from 40-150 hz
Frequency response: 22hz - 150hz
15" cast frame high excursion woofer
Adjustable level control (volume)
Speaker level & line level inputs
Phase adjustment
Lfe input
Auto-on sensing
User selected polarity switch
Hi current, class ab amplifier
Elegant black
Bass reflex design
Weight: 32kg
Height: 59.2cm x Width: 47.6cm x Depth: 47.6cm
