I started the car this morning, after driving it yesterday with no problems. backing it out of the garage I heard a fanbelt squeal. "Ah.. I think, better check and change the belt soon." Then i realise the steering is heavy...
Popped the car back in the garage and popped the bonnet. The serpentine/fan belt was VERY loose. The belt itself was intact so my prime suspect was the tensioner pulley, sure enough it's moved to it's full extent (to take up the slack, which makes sense)
Then I noticed a metal ring laying on the cover panel at the bottom of the engine bay - it's the outer ring of the crankshaft pulley
The weird thing is the pulley ring doesn't look to have sheared. I don't know if it's normally a compression-fit or not but I'm guessing an entirely new crankshaft pulley will be needed. I'm also not sure how much work is going to be involved in replacing it. I'm guessing I can do it in situ, although it looks like it's going to be easier to remove the rad and front of the car..
