QUOTE
GTE with toyota means uprated rods (H shaped and proper low compression ratio pistons) FE means fuel economy so hign compression for fuel economy......adding boost will fook this up.............
fishtits....GTE does not mean uprated H rods, and low compression pistons
G wide angle valve head
T Turbocharged
E Electronic fuel injection
and
2 being the block generation
JZ Engine family
as a side not the is200 being
1G-FE is...
1 Block generation
G Engine family
F Narrow valve head
so technically you could re-designate a Supercharged is200 engine as
1g-FZEand roops engine would be re-designated a
2JZ- GZE....
Z being the designator for Supercharged....
- The first numeric characters specify the engine block's generation
- The next one or two letters specify the engine family
- The suffix (separated by a dash) specifies the features of the engine:
the is300 engine in std form is a GE
the rods on the 2JZ engines are identical, however the rods on the VVTI GTE engines are, indeed thinner!!....
both GTE and GE use the same crank, bearings only big difference is the pistons, and the fact the gte block is fitted with oil squirters to cool the underside of the piston skirt.adding boost hasnt fooked up all the other hundreds of boosted GE...engines
QUOTE
For what its worth the installation on your car could well have been done by Steptoe & Son.
BANG OUT OF ORDER
QUOTE
The air filter location is a joke
i agree
QUOTE
.but hey ho you pays your money & you take your choice.
again your out of order.....Roop had a choice, and as far as i am aware, Prolex was one of his choices, he chose to go elsewhere
QUOTE
but will say to any IS300 owners looking to follow you to undertake vigorous due diligence before parting with any money
i agree, ....is300 owners should consider the company that has done Roops car, That company, was the authorised fitting agent in Europe for the Supercharger , and as they have a Registered Business premises, you can visit and see other cars to compare the work on, the proof is in the pudding.!!
Dave, i think you have been utterly unfair is your comments, ........is this sour grapes because he didnt come to you, this is how it is coming across, shielded by loose tech talk and inaccurate facts
if you are going to post, stating FACT and EVIDENCE ensure it is FACT and EVIDENCE!!!,
