QUOTE(B15RUP @ Sep 9 2008, 08:43 PM)
Even though I have never met you in person, are you feeling alright?!!
There were two power runs carried out with a couple of hp difference between them. The manufacturer claim the kit will push to in the region of 305HP and they have both A/T and M/T in the states.... I have had the CAT removed too, so the power achieved adds up.
I have some info regarding the auto-box that I researched, will try find it. The main thing is that it has been achieved here in the UK, the car is complete, is back on the road and it gives fellow IS300 owners an insight of what could be achieved if they consider the supercharger kit themselves.
I'm fine thank you.
Fact is the IS300 auto gearbox is not capable of an accurate dyno as it can't be held in a particular gear to enable accurate readings to be taken.
Manual is300 no problem...........pre 98 Soop no prob auto IS300 no way
IS300 auto will not work end of.............
I'll also say that driven with any sort of ooooopmhh your car will go pop soon as you need more fuel and uprated rods/pistons as the 2jz-fe is like the 1jz-ge in rod/piston configuration.
GTE with toyota means uprated rods (H shaped and proper low compression ratio pistons) FE means fuel economy so hign compression for fuel economy......adding boost will fook this up.............
I did tell you this when you were deciding wether to go for turbo or s/c a while ago.
Can you publish the AFR ratios you are running ?
For what its worth the installation on your car could well have been done by Steptoe & Son. The air filter location is a joke as is the ecu location...but hey ho you pays your money & you take your choice.
I hope you enjoy many miles of trouble free motoring but will say to any IS300 owners looking to follow you to undertake vigorous due diligence before parting with any money
