Full Version: Cut Out At 80mph Then Wouldnt Start
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 / SPORTCROSS > Engine & Transmission
waynejordan02
i was driving along the A13 doing 80 when i lost power no responce pulled over and tryed starting the car again it started then cut out after about half a seconed tapped. managed to get it started and got home went back and tryed starting the car and same thing cut out straight away anyone had this before i do have a s/c fitted and was wondering if it was something to do with that.
thanks
wayne
any help would be great thanks in advance.
Battery?
Alternator gone so no charge?
waynejordan02
QUOTE(sparkystav @ Jan 30 2008, 09:58 PM) *
Battery?
battery was fine keeped turning the car over on the side of the road for about 10 minutes checking diffrent things each time.not sure if my piggy back ecu is on the way out does this sound like a fault the black ecu would cause
Possibly,
Disconnect the Ecu and join the wire thats been cut back together and try the car.
QUOTE(waynejordan02 @ Jan 30 2008, 09:53 PM) *
thanks
wayne
Do you have the TTE black ecu fitted to ?
waynejordan02
QUOTE(Gord @ Jan 31 2008, 04:16 AM) *
thanks
wayne
yes have the black ecu with four wires
You need an HKS FCD (Fuel Cut Defencer) I think mate
QUOTE(waynejordan02 @ Jan 31 2008, 01:53 PM) *
thanks
wayne
waynejordan02
QUOTE(DJ Wozza @ Jan 31 2008, 02:41 PM) *
is that the one you showed me at the tdi meet wozza
waynejordan02
QUOTE(Gord @ Jan 31 2008, 02:45 PM) *
thanks
wayne
i know wozza has recomended one is that the best option gord
Yes Wayne,
you can get them from TDi or other HKS Dealers
As i said in another thread, if you can find a Greddy BCC their a better option than the FCD.
But their pretty rare.
QUOTE(waynejordan02 @ Jan 31 2008, 03:13 PM) *
thanks
wayne
Yes, lots better than the TTE black box mate biggrin.gif Not hard to fit, you use the same 4 wires biggrin.gif
waynejordan02
QUOTE(Gord @ Jan 31 2008, 03:54 PM) *
thanks
wayne
can you use any hks fcd or do they have to be for the is200 s/c
QUOTE(waynejordan02 @ Jan 31 2008, 03:57 PM) *
thanks
wayne
Its the STD one you want
Correct Gord, on about setting 8.
waynejordan02
QUOTE(sparkystav @ Jan 31 2008, 03:39 PM) *
whats the diffrence are they the same to wire
Their the same to wire,
basically the Black box, sends the correct inlet signal to the ecu upto a point then it sends a capped signal to stop fuel cut. The BCC does exactly the same.
The FCD sends a lesser signal right through the range instead.
