Hi all,
Finally had the Transmission Fluid Changed by the Local Garage and they new what they were doing plus i handed them the valuable advise submitted here
(Thanks a Lot) which made there job a lot easier and quicker hence cheaper..(£75)
Having a chat, they mentioned the Oil was black and smelled burned so was overdue a change, the Mesh Filter was gunged up, he had to leave it to soak ina parafin bath for 45mins before cleaning it up. The used all the Fluid 5lts and looked up the Fluid levels required and said that it was set the correct levels when cold, hot and going throught the grears etc..
So when i check the fluid level what should i be looking for please? Want to make sure it is correct for my peice of mind
If it is low i will have to buy some more ATF-Type IV fluid (oouch).
Also sorted the LPG bug out and looked at the ECU via the Laptop and no codes were coming up even though the engine light pops up from time to time??
Any suggestions please?
It is running a lot smoother and the gears changes are not even noticable has well has quicked of the mark, overall well pleased.
Cheers for the pointers and look forward to continued advice
Dibslpg
