Full Version: Front Seat Removal
Lexus Owners Club > Lexus Models > LS 400 / Lexus 430 / Lexus LS460 / Lexus 600h
Fergus the dog
I have a 1995 LS400 and I want to remove the drivers seat.
Although I can see the four bolts that hold the seat to the frame, do I need to do anything to disable the air bag system, or will just disconnecting all the seat electrics work.
I've looked on ALLDATDIY.COM but no such advice re seat airbags etc
M.IQBAL
hi
fergus i dont think the Mark 3 has seat airbags?
when i removed my seat on my 96 i just undid the 4 14mm bolts and out it came - replaced it no problems have occurred
hope this helps
regards
miq
Fergus the dog
QUOTE(M.IQBAL @ Feb 25 2008, 04:05 PM) *
hi
hope this helps
regards
miq
Hi thanks, I didn't think it had seat airbags, ibut someone had mentioned the SRS system in another thread I read on another issue, and it got me thinking
Cheers
ROYT
I thought the SRS was on the seat belts?
Is that right?
Haylands
SRS stands for "secondary restraint system" it means all other forms of restraint apart from the standard seatbelt (primary restraint system) so it includes airbags and seatbelt tensioners and pre-tensioners.
Pete
simontaylor
On my UK '95 MKiii car I just raised the seat and removed the 4 bolts.
I was an easy job, see this link for some pics too.
I'm not sure if I saw any seat airbags, but I did not need to unplug the seat from it's ECU.
Why do you need to remove the seat..... good luck anyway.
http://www.lexusownersclub.co.uk/forum/ind...mp;#entry471361
