QUOTE(Shiner @ Feb 25 2008, 05:05 PM)
I am a new and delighted LS430 (2004 model) owner. I am taking it to France, Normandy, next month.
Can anyone share their experience of using Light deflectors on the High Intensity Discharge bulbs on this model. Can the light deflectors do any damage to the light covers?
Also am considering updating the 2003 version of the Satnat disc, is it worth it for around £150? I am advise the latest version came out Oct 2007.
Incidently,I was amazed to find that there was/is no warning triangle that comes with the car.You name it and it's standard equipment except for this...well never mind there goes a tenner.
Hi
Light deflectors are a waste of time and just mess your headlights up as Glenn says don't bother.
The latest sat nav disc is a duel layer disc with 8.5gb on it, I upgraded mine from a 2001 car and it was much better, take yours out and stick it in your computer and see how big it is.... they are only about £100 anyway and you can get them on line here.
http://www.lexus-mapupdates.eu/They are very quick to send it, came in about 2days from europe
It is in the boot on the right hand side under the removable floor section next to the lift up wheel well cover (if that makes sense) You have to remove two 10mm bolts, toolkit helps here, you can then lift it up enough to get the disc out.
As for a triangle, you will never need one now, you drive a Lexus, they don't break down.......
Glad you like the car, they just seem to keep growing on you....
Pete
