Full Version: Help Needed With Is250 Wheel Change
Lexus Owners Club > General Lexus Forums > Wheels & Tyres
neal
Have changed original 17" Lexus wheels off my IS250 and replaced them with 18" chromes. They are original Lexus 18" grand prix chromes with Goodyear F1 Eagle tyres (225/40/ZR18 92Y) all round. Have included a coiple of pics but wish to know of a company in the midlands who could advise / set up the tracking for the rears. Abit worried that i may incurr rear tyre wear or worse still do damage to suspension.
Why would they need setting up ?
What is the worry about damage ?
I have the 18" Sport Wheels from the IS250 and they run 255/40x18" Tyres so I am sure there shouldn't
be a problem if the wheels are running the std offset.
neal
QUOTE(neal @ Feb 28 2008, 05:07 PM) *
I have had this on a different topic but comments were varied to say the least. By all means view it and see for yourself. Having gone from 17" to 18" (agreeable that its only an inch) the tyres are all the same. 225/40/18. Previous ones being 225 and 245 profile. Some say they look skinny on the rear and some say i will incurr premature rear tyre wear. I havent't had them tracked either as i am unsure of settings to use?
I certainly don't want to damage the car in anyway but also don't want to keep changing the tyres at silly intervals.
It depends on what those rims are designed to run with. 225 sounds a bit slim to me.
Contact your dealer to advise, but I would expect the wheels to have 235, 245 or 255 (as on mine).
Find out the Rim Diameter 8j 8.5j etc then compare to other IS250 members.
neal
QUOTE(neal @ Feb 28 2008, 05:53 PM) *
Have already consulted dealer and they confirmed that the CORRECT tyre size / profile are being used.
Parthiban
Sorry to stick my nose in here again as I feel slightly responsible for all this....... unsure.gif
In terms of the actual car, I can't see how it would do any damage to your suspension, people put different wheels on different cars all the time - as an example my dad's CLS comes as standard with narrower tyres (8" wide I think) and he has the optional wheels which are 9.5" wide at the rear. I'm pretty sure Mercedes wouldn't do this if that kind of difference would damage the car - there is no other difference mechanically to his car.
However, tyre wear is a completely different issue which Lexus don't seem to be very good at - my IS200 with standard wheels and tyres wore through its fronts on the inner edge really quickly, as it has for many others, so they don't seem to know what they're doing.
I'd make sure to keep an eye on the wear, and check that they are wearing evenly. Other than that, speak to Tony (Wheels in motion) about any of his approved places in your area that you could have your geometry checked, as this is the part that many people on here have found to be one of the most important things to have correct on your car.
I hope that makes you feel a bit better, but I'd be very surprised if it caused any serious damage smile.gif
neal
QUOTE(Parthiban @ Feb 28 2008, 07:56 PM) *
As i butted in on another post, i thought i would open my own topic relating to this matter.
Thank you VERY much for your input. I am worried but i may just be being stupid. I was just reading Tony's new venture, unfortunately its miles away from where i am. Fully appreciate swapping wheels is common and plenty people do it. A second opinion or a specialist would DEFINATELY put my mind at rest. I am VERY reluctant to drive it at the moment. I have to drive to Scotland next week then back to Derby, then to Gatwick airport. Will definately keep an eye on tyre wear front & back.
maneesh
Tony knows good geometry people all over the UK. I'm sure he can refer you to a qualified person in your part of the world.
neal
QUOTE(maneesh @ Feb 28 2008, 08:52 PM) *
Having read of his new venture he sounds a very talented person. How do i get in contact with this guru? If you are viewing this thread Tony, your input would be invaluable.
aztecbandit1
Hello Neal thought i'd just pop over to your topic and have a look at your lex mate and very nice it is too biggrin.gif not sure on your tyre issue i'm afraid unsure.gif smile.gif
chris32IS200
Neal,
Don't have any valuable input on your topic Neal but WOW, NICE CAR M8, real head turner..
neal
QUOTE(aztecbandit1 @ Feb 28 2008, 11:00 PM) *
Thanks for looking and reading various posts. Thought i'd mention pics as you mentioned you liked them on Chris's welcome topic. Thanks for your input anyway regarding tyres / wheels. Probably me just being a censored.gif
dazz32
Hi mate like the new wheels on your car...as regards to tyre issue dont see there being to much of an issue other than having slightly wider tyres at the rear would improve grip,handling etc.....but you would have to ask Tony ( WIM Wheels in motion )..on that issue..but yep lovely looking wheels and car looks good. biggrin.gif
neal
QUOTE(dazz32 @ Feb 29 2008, 10:08 AM) *
Rob
you will not damage the car - and unless the rears were wearing quickly u have no concern for huge abounts of tyre wear on ur new car either - i would however contact tony and ask for his advice and ask him to explain the effects of the larger wheels.
if you take the centre cap off you will find a number that starts with AM - what is it and i will tell u the correct size of tyre that should be on the wheel.
neal
QUOTE(Rob @ Feb 29 2008, 01:08 PM) *
Thanks for that Rob. I have actually confirmed with dealer that the correct size / profile tyre are fitted. Do you know how i contact Tony? Thanks once again Rob for your input. It is appreciated.
neal
QUOTE(neal @ Feb 29 2008, 04:48 PM) *
Comforting to know of the positive comments given by those of you that have read this. It doesn't feel quite right but having said that it wouldn't compared to before would it icon14.gif
