[quote name='nigel f' post='559630' date='Jul 4 2008, 08:43 AM'][quote name='skeet94' post='518774' date='Mar 8 2008, 10:11 PM']If you're willing to wait I'm doing a complete overhaul of the brakes on my Aristo. This is what I've ordered from Gaz and will let you know how I get on:
DBA 5000 series 2 piece front discs paired to Endless CCX pads fronts
DBA standard slot discs paired to Endless SSS pads rears
Motul Dot 5.1 brake fluid
Toyota Caliper refurb kits for both Supra 4 pot calipers and Aristo rear calipers.
I can give you a comparison to what I have now:
EBC drilled & slotted discs with green stuff on the fronts
stock rear discs with green stuff on the rears
unknown brake fluid that's not been changed in 3 years now (about time it got done!).
I'm almost certain the feel, fade, etc will be almost non-existant with this setup. Whatever you do stay away from EBC stuff though - it's not good stuff whatsoever. Loads of fade, loads of warping of discs, etc...I'd say the Supra caliper upgrade would be the best thing you do - but I'll tell you how much better it'll be. I picked mine up from the US for £200 including shipping...so a pretty good deal considering.
All in all I've spent £1200 and I'd much rather do the Supra brake upgrade with everything listed above than any other cheap BBK (D2, Ksport, etc).[/quote]
Any updates on the system, and the balance?
As I am just about to embark on an upgrade for my GS430 and was thinking of going the same way, I like the DBA disks I had them on the GTR, and my mate has them on his Supra and they work well on the UK brake set up on the supra, it just the balance, and with the master cylinder beeing different I was ondering
Nigel
[/quote]
Hi Nigel,
There seems to be some huge delays with the DBA discs - so I'm still waiting on these and since Gaz is off on a much-needed holiday - I should hear something back from him by the end of tomorrow. These should be on by the end of the month if all goes to plan
Mitul.
