MAT_8N
Mar 7 2008, 12:51 PM
how do i get my spark plugs out!!
i've got new ones to put in and had a quick look after taking the engine cover thing of but i'm flummexed as in how to get the damn things out!!
also, where's the fuel filter?
ta
Matt
lutonmatt
Mar 7 2008, 08:17 PM
when i did mine it took me about a hour and i changed the leads when i did it as one fell apart when i took it off if i can remember it was only a couple of nuts to get the cover off and the cover just lifted off
fuel filter i dont know
MAT_8N
Mar 7 2008, 08:32 PM
QUOTE(lutonmatt @ Mar 7 2008, 08:17 PM)
i've done it! took my stupid blind to the obvious head off and put my sensible head on!!
took me about an hour too. changed the fan belt thing and air filter too
sussed out the fuel filter too!!
fuel and oil filter/oil change in the morning then its just the brake pads and my service is all done! just need to book it in for the timing belt(waterpump maybe too) then she's good for another 60k miles
all parts imported from USA and fitted myself!! saved a fortune
Ross LS400
Mar 8 2008, 08:34 PM
QUOTE(MAT_8N @ Mar 7 2008, 08:32 PM)
Its a good feeling doing your own servicing. That way you can say "my car has been serviced" rather than "I have another stamp in my service book".
I hope Rock Auto were good to you mate. My stuff arrived very quickly.
Ross.
MAT_8N
Mar 9 2008, 11:54 AM
QUOTE(Ross LS400 @ Mar 8 2008, 08:34 PM)
Ross.
rock auto were spot on but i ordered front brake pads and i dont think they'll be the right ones? uk/usa spec? i haven't checked yet.
and i got stung for the import tax!!!! think i was unlucky but it still worked out much cheaper! 80p for spark plugs!!
lutonmatt
Mar 9 2008, 04:01 PM
80p that was cheap when i did mine i put bosch ones in and leads got me £55 trade price
MAT_8N
Mar 9 2008, 04:32 PM
$1.66 for bosch ones...that works out at about 80p!!
lutonmatt
Mar 9 2008, 04:41 PM
cheaper then i payed for ones for the trans am payed a tenner posted for new bosch super ones
GoldfingerLS
Mar 9 2008, 05:53 PM
80p per plug sounds a bit too cheap for kind of plug the 1UZ-FE needs. I think on that model the correct plug is the Denso Iridium tipped one or equivalent. ???
MAT_8N
Mar 9 2008, 06:06 PM
Yup, they're platinum tip ones.
one of a choice of about 8 including denso,ngk and bosch.....believe it or not i didn't go for the cheapest ones!
http://www.rockauto.com/catalog/x,carcode,...3,parttype,7212bosch 4202 is what i got. $2.11 now i paid $1.66.
fine i think for my engine?
GoldfingerLS
Mar 9 2008, 10:23 PM
According to the factory manual the correct plug for the 96 LS400 is
Nippon Denso - SK20R11
or
NGK BKR6EP-11
The NGK BKR6EP-11 is a platinum plug according to the NGK website:
http://www.ngk.com/results_app.asp?AAIA=1187513The SK20R11 is an iridium plug and is the recommended one for the 98+ VVTi LS400 but i guess because its an American reference they might have specified something different for the 96 model ??
According to the the Denso website the correct plug for the European '96 - '97 LS400 is PK20R11 which is a platinum plug. (but no harm if you used iridum ?)
http://www.globaldenso.com/cgi-bin/global/...=maker47car.csvAll in all i think you have the correct plug (with the correct gap) and you got them at a good price too.
Also a good idea to use a small bit of anti seizing compund (copper grease) on the thread since they will come after a long time.
I paid something like £9 or £10 each when I did plugs a while ago. You live and learn
MAT_8N
Mar 9 2008, 11:03 PM
i did look into it before i bought them.
i got all my service parts from them. the oil filter,air filter, fan/alternator belt thing, fuel filter and plugs and it came to $78.85($80) + about $30 postage. $110 at todays exchange rate is about £55/£60.....i got caught for £20 import/vat whatever it is but its still only about £80. i bought some semi synthetic oil and changed everything myself, which was a doddle.......all in it was about £120ish quid for a service and plug change which i thing was a good price!
i was wary that the stuff might not be right but it was all spot on and arrived 48 hours after the order!!
GoldfingerLS
Mar 10 2008, 12:09 AM
thanks for sharing the info, good to know for future reference if anyone needs to order parts. even after the £20 duty its still well worth the saving.
How did you get on with the fuel filter ? did you do it without a lift on axle stands ? i think like the mk4 its located somewhere near the rear diff. I got my mechanic to do mine while he had the car up in the air.
MAT_8N
Mar 10 2008, 08:27 AM
i haven't done the fuel filter yet. i had the front end up on axel stands so could just get through to the back for a look and a fiddle, but there wasn't much room. my drive is on a slope so i needed to turn it round and jack the back end up. looking at it though, again its a very simple job(just near the diff on mine too) just a bit messy with the fuel that leaks. i'll get it done soon, probably take about 20 mins!! everything is so well thought out and easy to replace.
GoldfingerLS
Mar 10 2008, 10:10 AM
fuel filter is not a difficult job, its an in-line type of filter and got plenty of working space, only draw back is its under the middle of the car but if you got it lifted to get under it you should be ok. Just be ready to catch 1 or 2 litres of petrol so you dont mess up your driveway, i remeber a lot came out.
With all those things replaced you might get a slight improvement in mpg.
MAT_8N
Mar 10 2008, 02:17 PM
QUOTE(GoldfingerLS @ Mar 10 2008, 10:10 AM)
i'm watching it at the moment to see how it goes. it does seem a touch more responsive? or maybe its in my head!!!
click here.
