QUOTE(williz @ Mar 13 2008, 10:38 AM)
QUOTE(RichieG @ Mar 12 2008, 05:08 PM)
I have left the car sitting (running for 15 minutes) and the transferrring screen just stays on as if it is frozen...no activity.
As I said my phone disconnects once I initiate the transfer (which I believe is supposed to happen) but it never makes connection again unitl I cancel the transfer action.
Can anyone tell me where I am going wrong or what I can do?
Give me one or two days and I will do the process step by step, write it down and do a detailed description.
Meanwhile you can check your telephone numbers and make sure that you have no blanks in there like +49 178 342 567. such numbers must be changed to +49178342567 or +49-178-342-567. the RX hands free system don't like the blanks and fills up the rest of the tel. number from the first blank with "IIIIII"'s.
Names should not contain special characters like "umlaut" or accents.
Now we transfer the N95 contacts to the RX hands free system step by step:
N95: Go to contacts, select options; mark/unmark, mark all
Select options; send business card, via Bluetooth
Now wait until “Last Device used:” screen will come up, in my case with about 500 contacts this will take 90 seconds.
Meanwhile start car, press info button, select Telephone, Settings, Transfer Phone Data, stop here and wait until your N95 shows “Last Device used:”
When N95 shows “Last Device used:” press “Overwrite” on Hands free, now Bluetooth connection will be disconnected, now select on “Last Device used:” screen your Hands Free, N95 will connect to your Hands Free again and starts transferring/sending data.
After data transfer is finished it will take some time (my bee 30 seconds or so) until your Hands Free screen will go back to the Settings screen.
Now you should have added your contacts to the Hands Free phone book.
Your RX400h model 2007 should support 2 phone numbers per entry. This means if you have more than 2 numbers stores at a contact in your N95 only 2 will be added, the rest will be truncated.
Hope it works!!!
