On my 2001 mark 1 I've noticed some blisters on the lower part of the driver's seat, close to where you'll find the controls of the seat itself.
Turns out that that part of the seat is not covered with leather, but plastic fabric, and that explains the blisters in spite of careful and regular maintenance of the leather (quite disappointing on a car like Lexus).
Anyway, in order to replace the damaged section, the "seat guy" will have to remove the seat.
Since he's quite concerned with the side airbags setting off (he'd better be!), he was thinking of disconnecting the battery altogether before starting the job.
The question is: is there any problem with disconnecting the battery? The guy said that on other cars (brands) if you do that you'll have to enter a bunch of "secret" codes in order to restore the radio, alarm and all sort of electronic gear.
I've never heard of such a thing; besides, the owner's manual says nothing about any precaution needed before disconnecting/replacing the battery.
Apart from that, do you think that removing the key from the dashboard is enough to prevent the explosion of the airbags?
I'll be very grateful for any info you might provide.
