Lexus is200 SE Sat Nav
Mar 16 2008, 03:37 AM
Can anyone help me with this problem. When I start the engine, normally all of the lights that should come on and go out, however as soon as I touch the bake pedal, the warning light comes on and stays on. I guessed it must be the brakes, so I went and changed the pads (front & back) hope that it'll resolved itself, but the problem still remain and the only way is to switch th engine off.
Can some one shed some light to this problem, it's quite annoying to see the red warning light on all times.
cheers
aztecbandit1
Mar 16 2008, 06:06 AM
Have you checked all the bulbs matey? rear brakelights and the one in the high stop light to see if there all working?
Mar 16 2008, 07:40 AM
^ what he said
aztecbandit1
Mar 16 2008, 07:42 AM
QUOTE(DJ Wozza @ Mar 16 2008, 07:40 AM)
^ what he said
the bulbman strikes again
Mar 16 2008, 11:16 PM
yes, the upper middle light seems faulty. I spent 10mins trying to yank it out but it couldn't come off. Is there a way to take it off easily?
cheers for the help.
Mar 16 2008, 11:45 PM
if you do a search theres a few threads about it, but i think if you push down the shelf it should pop out i may be wrong.
i know Woz has changed his so he might be able to help.
Mar 18 2008, 10:20 AM
I am trying to replace the faulty interior brake light. Is this light bulb suitable for it?
Lexus IS200 501 W5W Quad Led SIDELIGHT Bulbs.
Thanks alot
84Stoney
Mar 18 2008, 10:25 AM
QUOTE(Lexus is200 SE Sat Nav @ Mar 18 2008, 10:20 AM)
Thanks alot
not sure it is mate, ya mite be better off with a standard replacement, you dont want it to be brighter than your other bulbs, afterall, it's only a brake light!
Mar 18 2008, 10:36 AM
Thanks for the speedy reply, I am not looking for any fancy bright bulbs, as you said 'standard replacement' is what I am trying to do at the moment and at the same time trying to getting rid of the alloying red brake warning light on the dash board. I'll try the local part store later. Can you tell me what is the model/number/identify of these bulbs so I can order it from Internet.
Thanks again
Jackal321
Mar 28 2008, 11:03 AM
check your brake fluid
demolition217
May 4 2008, 08:27 AM
All fluids ok, all lighys working but brake light still on dash..........................any other advise?
click here.
