QUOTE(Rob's Lexx @ Mar 18 2008, 10:12 AM)
what are the benefits of these???
better stopping power??
its really quite subjective, it is suggested they give better pedal feel, which a fair few years ago was so..........as the older brake flexi pipes did have some sidewall flex in them, however modern brake lines are reinforced and are much better.
i suppose if you track the car, then they could be of benifit, as braided lines have a polymer outer casing aswell which is harder than the OEM rubber casing...the polymer casing would not chip like the OEM rubber would, causing an MOT fail
ALL modern car brake flexi lines are braided, its just you cant see it as the braid is covered by a black rubber outer casing
