Full Version: 2007-2008 Satnav Dvds
Lexus Owners Club > Buyers and Sellers Corner > Buy & Sell Parts & Accessories > Buy & Sell Archive
pobrown
I've got a set of 2007-8 SatNav DVDs for sale.
They were originally bought for a friends car, but like me he recently traded it in. I was going to use these discs in my new Prius, but it came with the 2007-08 disc already installed.
2007-08 4x DVD Set
Europe West
Europe Central
Europe North
Europe East
Part Number: PZ485-X03EU-A7
Check compatability with your system at: http://lexus-mapupdates.eu/
Enter your current disc number, and see if the disc recommended for your system matches the above part number.
Have seen the same discs working in a Mk3 GS300/430, 2006 SC430 and 2007/08 Toyota Prius. Probably works in most recent Toyota/Lexus models.
£100 including postage.
Cheers
Phil
zantiaboxer
QUOTE(pobrown @ Mar 18 2008, 10:06 PM) *
2007-08 4x DVD Set
Europe West
Europe Central
Europe North
Europe East
Cheers
Phil
zantiaboxer
2007-08 4x DVD Set
Europe West
Europe Central
Europe North
Europe East
Cheers
Phil
Don't know if I'm doing this right, but these are just the discs I'm looking for. Just aquired 51 LS 430 with outdated discs. Trouble is I can't find where the disc is located. If you can help, we could be in business.
pobrown
I personally have no experience with an LS430. However, a quick search brought up the following:
Sat nav is under the boot floor, you have a center piece that hides the spare wheel and two smaller side pieces, it is under the drivers side one, the panel is held in with two clips, take the panel out and you will see a silver box with a black front, it is bolted in position with two 10mm bolts, remove spanner from toolkit on the other side of the boot and remove the bolts. DO NOT DROP THEM THEY WILL RATTLE FOREVER. you can then, just about, lift the front edge of the dvd up enough to press the eject button (with ignition on) and the disc will pop out
I think, however, that the discs I have will not work on an LS430 of that age, but there is no way of checking until you get the code numbers from the DVD.
Cheers
Phil
zantiaboxer
QUOTE(pobrown @ Mar 21 2008, 06:00 PM) *
Cheers
Phil
Thanks for the info. If the weather is ok Saturday it will be my first job. At the moment Fri. evening it is blowing a snow storm.
Regards
Jon
zantiaboxer
Hi Phil, thanks for help but you were right, discs not compatable.
Regards
Jon
