Full Version: Does Anyone Know Where To Get Custom Spigot Rings Made?
Lexus Owners Club > General Lexus Forums > Wheels & Tyres
Anees
Hi guys,
I bought some alloys from ebay and the spigot rings that I got with them go from OD=72.6mm to ID = 60.1mm; the only problem is that the actual OD of the alloys is 74.1mm (says so on the box!)
I have tried to get spigot rings with OD=74.1mm to ID=60.1mm and no one seems to do them. I rang Wheelbase in Oldham and they suggested that I can combine spigot rings to get the correct size because the most common spigot rings I can get are:
OD=74.1 to ID=72.6mm
OD=72.6mm to ID=60.1mm
If I used these together I would get the correct fitment. I would rather just try and get a proper sized ring if possible or do you think combining the spigot rings should be okay?
I was thinking of getting some spigot rings made but don't know where to go??
Thanks,
Anees
Rob
Any decent engineering firm will be able to make some.
maneesh
Anees,
I think I have what you need!
I bought some hub centric rings for use with my TRD rims on the GS. I found out that I don't actually need them. I bought them off ebay in the US of A.
PM me your addy and I can mail them out.
Anees
llowen
QUOTE(Anees @ Mar 31 2008, 11:29 AM) *
Hi guys,
Thanks,
Anees
Hi
you have PM
I'm sure theres place onfleabay that do custom ones cause i got some to go from lexus to mazda.
