Hi Everyone.
No wish to bore anyone with yet more threads on the 'flat' battery situation.. I do feel however that this may be of interest to members who have suffered the battery problem on the RX
Following on from my previous postings, I would confirm. My car is a 2002 RX300. 26k miles .As new.
The car was bought only for use as a caravan towcar during the summer months and like many members I ran into trouble very quickly with a flat battery. The battery fitted was a 40amp hour Lucas
battery (I presume it was the OE fit)... A scream of a complaint about this to Lexus Oxford (where I bought the car) arranged for a 70 amp hour battery (AC Delc Toyota branded) under warranty.
OK so far.
I took the car off the road in November 2007 and I will be taxing it again rom 1st May. The car is stored in my garage adjacent to the house. The car is not locked. (the garage is) and the keys are removed.
I then charged the battery correctly on my electronic automatic charger.
The following are the results.
SAT 8th March ..... Following charge. Voltage 12.75 volts.
SAT 15th March Voltage 12.20 volts end of week 1
SAT 22nd March Voltage 12.01 volts end of week 2
SAT 29th March Voltage 11.80 volts end of week 3 (car still starting OK)
TUE April 1st (No jokes please) Voltage 9.47 volts. No Start . Everything completely dead.
Battery back on charge last night and has come back up OK this morning....
My RX is nothing special, it has all the electronic toys that are standard... I am however concerned that
ALL THE TIME the car is standing the RED FLASHING DIODE on the panel is flashing.
personally I do not agree with this. I feel the flashing red light should only be flashing when the car is locked and alarmed as per my BMW and my previous Mercedes. Not when ever the car is parked without the keys in.
I wonder could this be part of the problem ? Obviously the 40 amp hour starter battery should be replaced with the 70 ah one...
I will investigate the wiring of this diode to see if it can be re-routed... In the meantime guys, any ideas and comments on this would be welcome
Roy
From my stand now, the car will NEVER stand for more than 3 weeks without a freshening charge or a long drive.
