[url="http://www.lexusownersclub.co.uk/forum/index.php?showtopic=50338"]http://www.lexusownersclub.co.uk/forum/ind...showtopic=50338[/url]
8.5 ideal is between 235-245 seems like lexus set the front for comfort
10 ideal is 285 seems like lexus set the rears for performance(grip)
The setup is similar to the supra.
OEM usually use a slightly larger then recommend width for comfort.
Remember less tyre is more grip, quick wear and less comfort and vice versa.
What offset are the GS Sports wheels? IS OEM 17s are 50.
assuming the TTEs are also 50ET
You will need another 38mm on the outside and out, rolling the arches should give you this on the outside.
[url="http://www.1010tires.com/WheelOffsetCalculator.asp"]http://www.1010tires.com/WheelOffsetCalculator.asp[/url]
Using a skinner tyre will help
