QUOTE (Yve @ Nov 11 2008, 09:29 PM)
Hi Dec,
I have the same problem.
I took it back to the dealer 3 times now. Still no solution.
Does yours work in the meanwhile?
*EDIT* by the way, I owned an IS220d before, which never had this problem at all.
Regards,
Yve
QUOTE (Dex @ Apr 7 2008, 01:58 PM)
I have a brand new lexus is 220d se and I have had some issues when I start the car up.
The engine ticks over but it doesnt fire up? it takes maybe 5 seconds turning over before catching.
I have read the manual and I am still not clear.
I get into position in the sit, put gear into N, then depress clutch until light turns to green, the press start-stop switch once. Is this correct for the diesel?
I have tried, putting gear into N, pressing start-stop switch once, into acc mode, then again, wiating for check and other lights to come on, and then depressing clutch and pushing green stop-start switch - same thing happens.
Does the diesel need to warm up?
How do you start your IS?
Thanks,
Dec
It is not clear whether you have the automatic or the manual gearbox. "N" refers to the Auto... Leave it in park, keep your foot on the brake and then press the start button.
If you have the manual, keep it in neutral, depress the clutch fully until the green light comes on, press the start button and wait for a few seconds. The system does a diagnostic check, warms up the glow plugs then statrs the engine. This si what my IS220D sport does anyway. I know about the auto as they lent me one whilst mine was having an injector changew under warranty.
Don't expect marvelous fuel economy unless you do long runs. Using it for short runs you will be lucky to get 30-32mpg as it keeps the idling speed high to burn off the particulates in the catalyst until it is thoroughly warmed up. If you use it for short runs, give it a good blast at least once a week to stop the injectors from fouling up.
Enjoy, once you get used to all the high-tech tricks!!
Regards
Ray
