Full Version: Tte Compressor Parts List
Lexus Owners Club > Lexus Models > Lexus IS200 / Lexus IS300 / SPORTCROSS > Supercharging & Turbo Modifications
Maybe Pin this?
1; AM 27962 kit,hoses 38-46-50
38-46-70
50-59-110
50-59-80
60-70-80
2; AM 27959 housing, compressor outlet
3; AM 27936 ECU extension
4; AM 27929 valve, assy, bypass, cable operated
5; AM 27531 compressor unit
6; AM 27966 extension, P/S cooling tube bracket
7; AM 27934 tube adapter for throttle body
8; AM 27933 intercooler assy
9; AM 27964 stay, compressor bracket
10; AM 27960 bracket, airfilter box
11; AM 27717 bracket, compressor
12; AM 27961 bracket, airfilter fixation
13; AM 27928 tube compressor to I /C (2 part type)
14; AM 27843 tube, bypass, 38mm
15; AM 27927 tube, I/C to inlet manifold (2 part type)
16; AM 27931 housing, airfilterbox
17; AM 27932 insert airfilter TOYOTA P/N 17801 - 64010
18; AM 27965 bracket, intercooler
19; AM 27939 tensioner, belt
20; AM 27935 pulley (dia=130mm)
21; AM 27938 belt (5PK800)
22; AM 27930 housing, bypass to compressor
23; AM 27958 cable, compressor bypass, spare
24; AM 27963 support compressor bracket
Silentblock intercoolerbracket x2
Silentblock air box 20x20 M6x15
If you Email Florian at Florian.Bachus@toyota-f1.com
He's more than helpful with prices etc.
Hope this helps you lot wanting your own supercharger/custom setup.
I believe there is a page 5 to the documents but thats just the screws etc i think.
Edit:
Here is the Screw list also.
Great post and information Stav
84Stoney
Yeh man. Useful, thanks.
lexusIT
Talkin about ppl wanting a supercharger, you may interested to know that TTE only have 4 left, and the current price is... well a bit out of the market, considering what the residual value of our car is.
Anyway, that's what I got from him the other day when I asked about a compressor:
We have 4 IS200 compressor kits still on stock. Then they will be discontinued and not available any longer. Your price is 6.467,47 Euro
So still about £5K then! thats ridiculus!
I honestly reckon the most expensive bit of the kit is the charger.
You could pick up an old CLK one off Ebay cheap, then get the adaptor bits from TTE and make yourself a kit cheaper than that.
PCIronmike
aaronabbott
QUOTE(sparkystav @ Apr 8 2008, 01:20 PM) *
what about this stav
http://cgi.ebay.com/ebaymotors/MERCEDES-BE...sspagenameZWDVW
or 260227137877
http://cgi.ebay.com/ebaymotors/Eaton-m62-s...tem230238656902
or 230238656902
ive also found some other bits like the greddy emanage,but need some advice on what intercooler etc i'll need.so far ive sourced:- the 2 superchargers? (waiting to see if they'll fit or work)
greddy emanage
various intercooler tubings kits
yemgi
QUOTE(lexusIT @ Apr 8 2008, 09:55 AM) *
This price includes fitting at Koln in TTE's factory
aaronabbott
QUOTE(yemgi @ Apr 8 2008, 06:44 PM) *
This price includes fitting in Koln
can you buy them without fitting as id rather so it myself to save £££££££££££
If it includes fitting thats not a bad price, you'll have to save up, come with us on the next Ring trip, get it fitted and off to the ring!
Aaron,
the second one looks more like it, but you'd have to do a lot of research into it. It'd def need a new snout for a start (the bit with the pulley on)
Its basically the blades, body, and bearing that you'll save the most money on.
you'd have to Email Florian for a full price list really.
Also Rob may be the best to talk too as he's had his charger apart before.
aaronabbott
did you have a look at them s/c's stav
See above! ^
aaronabbott
cheers stav ive emailed florian so ill see what he says
watch this space
lexusIT
QUOTE(yemgi @ Apr 8 2008, 07:44 PM) *
well that's not what he told me, as the full quote was:
Your price is 6.467,47 Euro + 95,20 Euro freight costs to your delivery address.
of course I'm not much of a negotiator, considering that I am not interested at this price anyway.
Just thought I'd add this for clarity.
Rob
you could do somth with the first SC but you would have to make adaptors etc for the inlet as its part of the casing.
Actually its better to have the pulley type seen on the first SC than the one we have on the TTE/Bemani kit.
dont bother with anything that looks like the 2nd SC as it looks like it bolts onto a v8 so has a mounting flange and not a port (we need a port)
but for info our SC does come from an earlier model SLK
aaronabbott
QUOTE(Rob @ Apr 9 2008, 08:21 AM) *
thanks for that my problem at the minute is working out what s/c to use as ive spoken to florian and hes coming back to me with a price for the kit without the s/c and also a group buy for the last 4 remaining kits
Rob
Also speak with Bemani in Switzerland ( 1 hour from me) as they made the kit for lexus switzerland http://www.bemani.ch/english/home_en.htm ask for Nick as he speaks english.
aaronabbott
can anyone tell me if this s/c is eaton m62 all it has is a serial number,
http://cgi.ebay.co.uk/MERCEDES-C220-SUPERC...1QQcmdZViewItem
250233060421
Rob
QUOTE(aaronabbott @ Apr 9 2008, 04:43 PM) *
250233060421
no its a M45
aaronabbott
thanks ill keep looking
Rob
ld get somthing like this and just reduce the speed of the compressor a bit.
but before i buy i would want a good look at the unit although this one looks ok but hard to tell unless seeing it in person.
ebay # 300212867684
would have to find an outlet adaptor but that wont be too hard
aaronabbott
how do you reduce the speed
Rob
change the size of the pulley on the compressor or the water pump
aaronabbott
i had an email back from florian earlier and he said the kit was
6385.94 eur +94 eur shipping
6467.47 eur including fitting in germany
and he could do a discount........................................................................
..............................................wait for it..............................................................................
....................................................................of 205 eur per kit if we bought the last 4
lexusIT
QUOTE(aaronabbott @ Apr 9 2008, 06:27 PM) *
bargain!
That does include the Uprated Silver Ecu connector, and a decatted manifold though.
seecarr11
Good day, I'm new to the IS and i was thinking about atempting the same (finding an alternate charger and getting the other parts made)Trying to ship a kit from germany (if they still have icon14.gif ) to the US is just too expensive to be worthwhile. I thought about turbocharging instead but i prefer a bolt on option that doesn't require modifying internals and too much guesswork. whistling.gif How's this option going? i saw a few eaton m62's on ebay but they were for a pontiac or something (the snout looks alot longer unsure.gif ) Does anyone have the assembly instructions/specs for the tte charger kit so maybe i can start tracking down the intercooler, pipework and maybe the pulleys? Also i like the oem look the tte air filter has. does anybody have a used one they're willing to sell? shifty.gif
Any advice would be appreciated
I have a 1G-FE RHD IS200 SE with the TRD circuit suspension coilovers and i already upgraded the brakes.
Carles
Other site to see alternatives to tte...
http://www.capa.com.au/eaton.htm
now added the Bolts list
hyperman
If someone got the complete pricelist please post it here, that way we don't all have to e-mail Florian.
TonyGoose
QUOTE(hyperman @ Aug 18 2008, 11:12 AM) *
Not much point in sending email to Florian now...
He left the company last May...
TG
As in the May just gone?
Have to find another correspondent then.
ProLex-UK
QUOTE(sparkystav @ Aug 18 2008, 06:06 PM) *
Nick is doing Florians old job.
hyperman
QUOTE(ProLex-UK @ Aug 18 2008, 07:18 PM) *
Could you pm me the contactinfo of Nick.
Tom-18
Can somone PM me the Contact info of nick too please! as i'll have to find out about parts and prices smile.gif
Thanks,
Tom.
hyperman
I have gotten word back from TTE and they were wondering why there was such a big interested in supercharger parts. whistling.gif
These are the prices given to me.
1; AM 27962 kit,hoses 38-46-50, 38-46-70, 50-59-110, 50-59-80, 60-70-80 no stock
2; AM 27959 housing, compressor outlet 222,88 €
3; AM 27936 ECU extension 598,59 €
4; AM 27929 valve, assy, bypass, cable operated 302,07 €
5; AM 27531 compressor unit 2019,43 €
6; AM 27966 extension, P/S cooling tube bracket 4,75 €
7; AM 27934 tube adapter for throttle body 520,41 €
8; AM 27933 intercooler assy 660,71 €
9; AM 27964 stay, compressor bracket 22,10 €
10; AM 27960 bracket, airfilter box 27,61 €
11; AM 27717 bracket, compressor 636,55 €
12; AM 27961 bracket, airfilter fixation no Stock
13; AM 27928 tube compressor to I /C (2 part type) 48,25 €
14; AM 27843 tube, bypass, 38mm 42,68 €
15; AM 27927 tube, I/C to inlet manifold (2 part type) 31,54 €
16; AM 27931 housing, airfilterbox 843,89 €
17; AM 27932 insert airfilter TOYOTA P/N 17801 - 64010 30,54 €
18; AM 27965 bracket, intercooler 5,50 €
19; AM 27939 tensioner, belt no stock
20; AM 27935 pulley (dia=130mm) 144,81 €
21; AM 27938 belt (5PK800) 28,29 €
22; AM 27930 housing, bypass to compressor 437,82 €
23; AM 27958 cable, compressor bypass, spare 30,54 €
24; AM 27963 support compressor bracket 17,90 €
Silentblock intercoolerbracket x2 no Stock
Silentblock air box 20x20 M6x15 no Stock
Hope this helps
Rob
u can get the bypass valve assy for about £40 ...but not from TTE
Carles
I decided to make my own compressor so I need your help.
First I need to buy a 98-00 MB 230 CLK/SLK compressor, that come with electromagnetic clutch but can be removed easy.
I need know the size of some parts.
Intercooler no problem:
TTE Intercooler
Core Size
430 x 115 x 51
Inlet/Outlet Diameter 54mm
New Intercooler
Core size
531 x 180 x 63
(180 - 20 = 160mm high of unrestricted airflow)
http://www.lexusownersclub.co.uk/forum/ind...showtopic=52070
Housings no problem will be built on the fly.
Problems:
TTE airbox, I don't wanna direct air filter.
Tensioners, pulley and by pass.
The pulley of compressor have 130 mm. of diameter and can be built, but how wide?
I need also pics of the accommodation of the tensioner.
How does the bypass? When you open the throttle is opened too? What it's the function?
Somebody have a pic of the layout?
The compressor bracket must be built on the fly, seems difficult.
Thanks in advance.
for the supercharger mate, the electric clutch is still built into the TTE ones, just the wires cut off and three little bolts keeping it permanatly connected.
The bypass is attached to the throttle, its open when your off throttle and then the wire attached to the throttle pulls it shut, stopping it bypassing. with a spring to help it open again
It wont be easy to make the kit mate, why not just buy Gords? i'm sure postage isnt that bad overall.
Carles
QUOTE(sparkystav @ Oct 6 2008, 11:03 AM) *
Thanks for your answer!
I think the same thing, but obviously not, is proving difficult for me to buy one and I have made several attempts. On the other hand I like the challenge, I see it feasible (with the help of all of you) and I suppose that cost will be less. All these factors have made me decide.
D8driver
I guarantee you that building a kit yourself will cost far more than Gords offer.
Since the price I wanted for a perfect compressor allready is out of your budget (it was extremely low compared to the prices worn ones bring on ebay) building a kit will become a hopeless task and it might be wiser to keep the car original.
So my only advice will be to keep is realistic and count in that a kit will cost you over 2000 pound in the end or stay away from this project (and be honest, if it was cheap or easy numbers of member would allready have done the trick without buying overpriced TTE kits)
Carles
QUOTE(D8driver @ Oct 8 2008, 06:43 PM) *
I have already tried to buy a compressor for 2000 pounds but this has not happened.
Thanks for your advice but indeed your argument puts out of my budget the price of the compressor that you offer me.
Add new info in this topic:
http://www.lexusownersclub.co.uk/forum/ind...pressor+rebuild
"u can also order a cable operated valve instead from magnusson
for info the pulley on the compressor is 110mm"
"the pulley on the water pump is 130mm"
Edit, the correct link is: http://www.lexusownersclub.co.uk/forum/ind...pressor+rebuild
MeMo
if i was you i would forget it mate, as this is what i looked into doing before i went with the turbo setup, you would be best puting a turbo on your IS as the bits do not work out that much to buy, i think the one item that would cost the most would be the manifold ( ie' custom made one ) i put a turbo on my IS 3 years ago and i did it by buying it bit by bit and when i had it all i fitted it, worked out about £1,200 smile.gif
D8driver
If you're good with tools a turbo would be the way to go (a new Garett or IHI with a bit of luck won't cost half of a M62 that will set you back approx 1400 pound, and good ones with not too high mileage are rare).
By the way you could go BOV and drop the valve (I shut mine and ran the car for severall months on just the BOV which worked out just fine)
Carles
I should discard the turbo because the ITV (MOT) don't accept it, require a lot of money and paperwork to legalise and the S/C it's more easy to do.
Also I hope to find a very cheap MB compressor in some scrapyard, and at the moment two major problems have disappeared, the setup with a HKS FCD and the bypass with a BOV, but the TTE airbox, the tensioner, and the compressor bracket worries me.
I'm will be very grateful if someone can be puts some pics about of details about tensioner and the rest of the installation taken from near.
