Full Version: Induction Kit
Lexus Owners Club > Lexus Models > Lexus Imports > Altezza
TezzaMan
Hi all!
I've also bought a HKS racing suction kit from ebay. The kit is incomplete (missing a bracket and instructions) But for £40 I thought what the hell, I'll make a bracket and work out how to fit the kit. So I took the airbox out, disconnected the sensor, but then I found more smaller pipes and other connections right at the bottom of the airbox (and the round bit with a pipe coming out at the top of the airbox).
See pic
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...N:IT&ih=003
http://img245.imageshack.us/my.php?image=image031ag4.jpg
I just don't know what to do with the other connections. Any ideas? It would be GREAT if someone had one of these kits and has instructions!!
Thanks. R
Noel
IIRC there's only one small pipe to block on top of the engine block, the rest can be disconnected and removed with the old air-box, the brown electrical connector is normally just cable tied out of the way...
It's very important to fit the MAF sensor in the correct way, the wires face forward towards the front out the car wink.gif
Keep the pictures of where they all go in case you ever decide to put it back to standard...
TezzaMan
I was concerned about the electrical connector the most.
Just wondering what all the other hoses do?
Never mind, if I don't need them, I don't need them.
Thanks again, R
IRLRs200
QUOTE(TezzaMan @ Apr 9 2008, 10:59 PM) *
Thanks again, R
extra hoses are vacuum hoses i think, at a certain rpm this would cause a flap in the airbox to lift allowing more air into the airbox. make sure you block off the valve on the top of the engine block as Noel mentioned otherwise the car wont run properly
