QUOTE(wildybeast @ Apr 11 2008, 06:01 PM)
ok. will try explain a little more .where the 6 pipes from the cylinder head meet there are 2 precats one for each 3 cylinders.where the cats are housed the pipework is approx say 4" wide and say 8" long then tapers down to say 2" and then carries on to the rest of the system.it is the cat housing that ime thinking of taking out and replacing with a smaller diameter pipe.possibaly the same diameter as the 2 down pipes which leed to the 2nd section of the exhaust.car runs fine at the mo but thought it may need more back pressure.thanks folks
doing thats fine - thought u meant putting even smaller pipe work in......
