I have a 1998 MKII GS300 and a small (slow) leak has developed at the grommet between the brake fluid reservoir and the master cylinder. If I flex the reservoir slightly I observe a small amount of brake fluid appearing on the grommet, apart from this the master brake cylinder is fine. However, I have not been able to source these grommets or even a reservoir that may come with grommets, everyone wants to sell me a new master brake cylinder (I did buy a reconditioned master brake cylinder but a faulty unit was supplied to me (twice) and so I had to put my original one back on ! but thats another story).
Is it possible to get the grommets, or a reservoir with grommets from Lexus ? Anyone know part numbers ?
Failing that can the reservoir be removed and the grommets re-seated after greasing with silicon brake lube ?
Joe.
