DALE69V
April 17, 2008, 5:10 pm
Hi All
Long time no write
Does anyone know how to get the Crank Pulley off as im havin some difficulty
Cheers Dale
garethr
April 18, 2008, 3:16 pm
Problem undoing the nut, or removing the pulley once the nut is loose?
DALE69V
April 18, 2008, 3:54 pm
[quote name='garethr' post='533748' date='Apr 18 2008, 04:16 PM']Problem undoing the nut, or removing the pulley once the nut is loose?[/quote]
Both at the min mate LOL
im off to buy a new breaker bar tommorrow as i broke the last one trying to crack the nut off
garethr
April 21, 2008, 11:01 am
There is a Toyota service tool to lock the crank while you heave on the breaker bar, but it was about 110 quid last time I saw a price. There's a similar tool on US eBay for about 60 dollars.
Don't use a torch on the nut unless you intend to replace the harmonic damper.
In the absence of an air impact gun, people have resorted to disabling the ignition, jamming the breaker bar against something solid, and using the starter motor.
mura
April 24, 2008, 2:50 am
I use a 5 ft breaker bar and lock the Crank via the flex plate access hole at the bottom of the gearbox.
Also you need a Pully extractor to get the pully off.
click here.
