Wittybebop
Apr 18 2008, 11:40 AM
Hi all got a TTE supercharger bolted onto my 1G-FE, however my concern is about the noise it makes, it is quite audible whilst driving even at 1,500 - 2,000 low end revs, going louder as revs build up, kind of sound like load transmission whine.
Any suggestions? BTW it doesen't seem to pull either, like just driving a normal car.
Rob's Lexx
Apr 18 2008, 11:48 AM
check the belt...might be slipping.
mine sounds just lovely
Rob
Apr 18 2008, 11:56 AM
its straight cut gears so it is noisy - disconnect the belt then drive it - if there is no difference u have an air leak in the pipework/bypass stuck open or ur supercharger is dead.
Apr 18 2008, 12:06 PM
QUOTE(Wittybebop @ Apr 18 2008, 12:40 PM)
It is defo noisier than standard, but I am worried as to why it's not pulling.
Who fitted the Supercharger ? Do you have any pictures ?
Check all the jubilee hose clips for tightness, the drive belt too, and try to get along to a meet
and take a look at another members S/C IS200 for comparison.
Apr 18 2008, 12:54 PM
Do you have an induction kit or the standard one? it could be just the normal noise.
But if your not getting anymore power, is the bypass wire working correctly?
Or like its been said check the belt is tight and all the jubilee clips are tight.
84Stoney
Apr 21 2008, 03:44 PM
I have nothing to offer other than what has been said above.
Just wanted to say that mine sounds lovely too! Thou the induction takes some getting used to.
Rob
Apr 22 2008, 01:30 PM
U also want to check if the unit has oil in it - u need to remove it tho to do this as the oil plug is underneath. approx 150ml is in the unit
Apr 22 2008, 02:24 PM
Tell me more Rob, I've not heard of this before ?
What kind of oil ?
Any pics of drain/refill point etc ?
Rob
Apr 23 2008, 08:22 AM
after doing a lot of research before rebuilding my unit i found out that the SC is not a "sealed for life" unit as we all believed (myself included).
underneath the pully assy there is a drain plug but the problem is our is mounted in such a way that u have to remove it to check the oil level - drain it out then refil would be better. On the mercedes the unit is mounted with the drain plug faving upwards.
I looked at rotating the casing so the plug was at the top but failed due to the mounting bolts being offset.
It is possible to make a sight glass to monitor the oil level and this is something i plan on doing in the future.
if u look at my rebuild thread 3rd photo from the bottom u can see the threaded hole for the drain plug
Apr 23 2008, 09:49 AM
This one?
Rob
Apr 23 2008, 12:24 PM
yep that the one - below and to the left in that pic - so looking at an assembled SC its below and to the left of the pulley
D8driver
Apr 23 2008, 01:45 PM
Rob
Apr 23 2008, 05:29 PM
thats for a differnt type of SC - but its true the oil smells - i think its just normal gear oil TBH.
as the plug is underneath u can just drain the oil out into a jar then u can measure how much oil was in the unit - u only need 1 bottle of oil also.
D8driver
Apr 24 2008, 07:31 AM
I did realize it's another SC. Might be interesting to phone a Merc dealer about the compressor. The SLK M62 eaton Kompressor (with magnetic clutch) used to be classified as service free but the guy I spoke told me nowadays they do check oil levell at a regular basis (so they might be able to specify the right type of oil).
I know a guy that put Castrol 60 gear oil in it without any problems.
this might be interesting
http://www.capa.com.au/eaton.htm
LennyLexus
Apr 27 2008, 07:02 PM
I too find my charger is running noisy at idle and the start of acceleration from idle (upto 1.5/2k), then the noise dissappears.
I have done 220 miles since it was fitted, I have checked that the 17" bolt on the tensioner is still tight (as recommended by Steve at Charlesworth), yes it is.
The problem probably occurred after bouncing the rev limiter in Neutral (was trying to hear the whine).
The noise appears to coming from the s/c region, but I cant see anything obvious, (belts all seem to be turning fine). Will check jubilee hose clips.
Thanks in advance.
Rob
Apr 27 2008, 07:34 PM
it has straight cut gears so will be noisy as there is always a bit of slack in them
LennyLexus
Apr 27 2008, 07:54 PM
Rob i forgot to add that when I press the brake (at idle) the noise stops...
Rob
Apr 27 2008, 08:20 PM
ok well i doubt then it has anything to do with the SC - i would have engine running with bonnet open and try to isolate the area of the noise - atch ur fingers for moving parts.......!!!!!!!!!
TigerFish
Apr 27 2008, 08:35 PM
Maybe the brake servo if it stops when you put the foot on the brake?
LennyLexus
Apr 29 2008, 06:11 PM
hmm doesnt always stop when I press the brakes..
Have kind of isolated the noise, I think its at the 30/40mm (smallest in set) hose connection on the left hand side of the s/c, this is probably because it was missing from the box, and the fitting centre had to cut the longer hose in half and used it on both connections, looked fine when it was being fitted.
Can someone confirm what the size of these hoses are and where i could get them from?
Cheers
click here.
