Full Version: Toyo Proxes R32a Tyres For Is250
Lexus Owners Club > Lexus Models > Lexus IS 250 / Lexus IS 220D / Lexus IS 250C
Suso
Hi chaps, I just completed 30K miles on my IS250, so I looked around for new tyres & thought about trying the Toyo Proxes R32A.
I got them from camskill for £380, and saved loads compared to the Dunlops. I've only driven 100 miles with them but they seem smooth and quiet.
The rim protector is quite thick, so hope it helps preventing scratching the alloys.
I am trying to upload a couple of pictures as I could not find any when I was buying them.
Tango
QUOTE(Suso @ Apr 27 2008, 06:29 PM) *
Yep, put them on my IS200 Sport last year..they're a very good tyre. Will probably put them on my 250 in place of the Toyo T1-R's when Toyo produce the sizes that'll fit my rims.
RobNorm
R32's were standard on my IS250
Tango
QUOTE(RobNorm @ Apr 27 2008, 08:14 PM) *
Yes, they were the alternative to the Bridgestones...trying to improve on the road noise I think. My rims are a different size to yours though whistling.gif
stevet
From the pictures you can see there is quite a difference in the diameter of the 245's against the 225's.
I'm on 22k now with my oem dunlops and going for Toyos next.
Musicmaker
I changed to TOYO's at 33,000 and now after 62,000 the fronts have about 5mm but the rears are only 3mm. The road noise defently reduced and I think they feel a lot better in heavy rain conditions.
I also changed the fronts from 225 to 235, with 245 on the rear. every service phone me to say the wrong tyres are fitted.
GaryC
QUOTE(Musicmaker @ May 18 2008, 08:32 PM) *
You changed to the Toyo's from the Dunlops ?
Barry Lavin
Im waiting for a new 220d which I am told will take four months so I decided just to change the front tyres which are getting a bit scruffy. I went to my local tyre place and told the guy that I wanted Toyos because that is what Lexus were switching to because of the road noise. The guy told me that I would be mad to change to Toyos as they were a mid priced tyre ( about €110) over here each as against € 160/170 for continental/Bridgstones which according to him were premium tyres and far better quality than the Toyos. Now I am in a quandary as to what to do. If this is true I certainly dont want them on my new jalopy. Are we seeing Lexus cutbacks or are the reasons for change true.
Tango
QUOTE(Barry Lavin @ Jun 13 2008, 09:49 PM) *
If he charged more for the Toyo's would it make you feel better? Toyo aren't inferior quality compared to Bridgestone or Continental, I prefer them on my 250 and 200 to either of them....less noise and more grip in the wet. Probably a softer compound than the Bridgestone so will not wear quite as well, but it's a trade off against better grip. My T1-R's on the 250 have done just under 20K and the rears are more worn than the fronts, but they don't need changing yet.
iceman67
hi tango is possible you could tell me the price of toyo for the is200 please
many thanks neil
Barry Lavin
QUOTE(Tango @ Jun 13 2008, 10:24 PM) *
Thanks for coming back with a reply .The price is not an issue its just that you normally gets what you pays for and I was a bit wary of the huge price differential. Also I know bugger all about tyres and he was supposed to be the expert.
Tango
QUOTE(iceman67 @ Jun 13 2008, 10:36 PM) *
many thanks neil
Neil,
Purchased the 4 off Toyo Proxes 4 TL 215/45R17 in October 2007 for £82.53 each. Total price inc. VAT, valves, fitting & balance was £422.76.
Last time the stealership fitted a Bridgestone Potenza to my 200 Sport I believe it was £125.00
iceman67
thanks tango for the info wolves lexus charged me 135 for dunlop sp9000
KnightUnit
I run the Kuhmo KU31's Sport Tyres, 215/45/17 got 30k each out the last 2 sets. £260 for all four corners balanced and fitted.
I say 30k, the rears and prob got another 10/15k miles left in them.
illestjt
I got Dunlops SP Sport MAXX for £90 each, as the alloys were being replaced under warranty I had them fitted free woop
chandru
changed mine to t1-r's as well when i upgrade from the OEM 17" to the hoshi 18". ride and noise is much better IMHO.
VrmmVrmm
43000 klms...almost 27000 mls...Just changed to the Toyo T1Rs from Dunlops.
The rears probably had 5,000 miles left in them but I prefer to change all four when I change.
The tyre guy thought that these tyres were really good ...I took his word for it.
The road noise I think is no better or worse. I have not driven in the wet with them yet
but they have a pretty impressive looking tread pattern for moving water away...I hope.
