jdeluna
Apr 30 2008, 03:54 PM
Hi!! im sorry for my bad english ... im from the Dominican Republic i have a Lexus is 200 with a 2jz-GTE engine with a atomatic transmission, since i did the conversion i havent been able to enjoy it. My problem is that when i start from cero at full trottle when it goes to change from second gear to third @ 5,500 rpm the car start to limit when is supposed to go up to 6,800 rpm and if i pull out the trottle a litle bit chages to third gear some times it runs perfect and passes the gear correctly without no problem at all.
Lexus2D
Apr 30 2008, 04:00 PM
Hi & Welcome 2 LOC UK
Sorry i carnt help but u live in a nice part of the world
Iv been 2 sosua
Gr8 Lexus BTW
LennyLexus
Apr 30 2008, 04:06 PM
Welcome
Who did the conversion? any more pics/links etc.
jdeluna
Apr 30 2008, 05:01 PM
Well i have a friend that has a Toyota and Honda services center he was the on that made the installation,many peoples had come with different theory's the first is that the sensor ecu from the Is200 is working side by side with the 2jz ecu and that could be a conflict but it must work like this because the 2jz ecu just do the engine work, now the other theory is that everybody knows 2jz comes with a lower differential than the IS 200 the other conflict could be that the speed sensor its not recognizing actual speed so its very confusing(thanks for the greeting and its so cool that you had been over my country i lived in Santiago which is the sencond largest city on the country , i will put more pics from the installation and the car )i did upgraded the intercooler because the one that its on the pic it was from the evo 6 that i had)
Apr 30 2008, 07:09 PM
You could try sending Obsessed a pm, he is a member on here from OZ, he has successfully done this to his car
and others
jdeluna
Apr 30 2008, 07:26 PM
How can i contact Obsessed????
Scorps01
Apr 30 2008, 07:27 PM
jdeluna
Apr 30 2008, 07:32 PM
thanks bro!!!
gsportcars
May 15 2008, 10:54 AM
Might be a stupid answer but worth a try...
Have you correctly adjusted the throttle cable? Only reason I ask is that I had a similar problem when I did away with the electronic throttle on my car. The throttle cable was very loose.
click here.
