Supercharged
May 2, 2008, 2:55 pm
Can anyone please help? I have a 54 plate IS200 Sportcross with a dash board lights fault. All the lights stopped working a couple of weeks ago and can't find the problem, the items I have checked are listed below. At the same time the rear fogs have stopped working though the light bulbs are fine.
All fuses i can find (both sides inside the car and under the bonnet) are working fine
The Rheostat is still working on the radio & air con displays
Replace rear fog switch, still the fogs and dash lights will not work.
All the dash bulbs have been checked and are ok
Any ideas?
John1986
May 2, 2008, 4:50 pm
no offence, but it happened to my m8. have u checked that the little dial hasnt somehow been turned that dims the lights
Supercharged
May 4, 2008, 3:52 pm
The rheostat was the first thing that i tried, i have since noticed that turning it has no effect on the radio or heater display so i may try taking it out to see if it is faulty. I still can't understand why the rear fogs wouldn't work though
May 4, 2008, 4:07 pm
It could be the rear fog switch then?
Is the plug def in the back firmly?
cause all illumination of the dash is on one circuit.
Supercharged
May 5, 2008, 4:56 am
I bought a new rear fog switch and fitted it but it has made no differrence.
Carles
May 5, 2008, 10:22 am
[url="http://www.bahamutcars.com/workshop/IS_98-05/contents/index.html"]http://www.bahamutcars.com/workshop/IS_98-...ents/index.html[/url]
[url="http://www.bahamutcars.com/workshop/IS_98-05/ewd/ewd368e/h_system/text/rfl-rhd.pdf"]http://www.bahamutcars.com/workshop/IS_98-...ext/rfl-rhd.pdf[/url]
[url="http://www.bahamutcars.com/workshop/IS_98-05/ewd/ewd368e/location.html?code=rfl-rhd"]http://www.bahamutcars.com/workshop/IS_98-...ml?code=rfl-rhd[/url]
I hope this helps.
Carles
May 5, 2008, 10:47 am
Also check the ECU-B2 fuse.
peter_bg
May 11, 2008, 9:32 am
Hi math has you find a solution of the problem, by me only the rear fog won’t work???
Full Colour Version:
Dashboard Lights
click here.
