Full Version: Computer Help Needed
Lexus Owners Club > General Lexus Forums > Lexus Owners Club Lounge
andy200sport
Not car related in anyway but, anyone on here a pc guru?
I've just been out and brought a self powered 4 port usb hub with the intention of running my broadband modem, cd writer and opitical mouse through it as i've only got one usb port on my laptop :( .
The mouse works fine though it but i cant get the modem to play, it powers up just fine but isn't getting a signal through the hub. The hub is a belkin pocket hub and the modem is a bt voyager. Any help would be appreciated
Cheers
Andy
Matthew_McNally
I've heard of problems where the modem draws practically all the power allowed by the USB spec.
maybe using the mouse and the modem means that there isn't enough power left from the hub to power the modem?
:geek:
andy200sport
Cheers for the reply Matthew, i've tried the modem on its own through the hub and still no luck, it seams to be powered up ok, i think that for whatever reason, the signal isn't going through it.
vince-com
something telling me it's a port conflict, I don't know much about PC (mac addict), but I have experienced that on my wife PC, with an external modem.
We had to select carrefully the port to have the modem running fine, maybe you can give an eye on the port selection.
Wallace
Did the computer detect it when you first plugged it into the hub? Have you read the instructions :P
javaboss
I had much the same problems.
USB supports 500ma power. Each port on most hubs support a max of 500ma. The BT broadband 'frog' draws the full 500ma and sometimes a bit more. It used to screw up the hub and the computer sometimes!
In the end, I threw the frog in the bin and invested 500 quid in a SpeedTouch 570 wireless ADSL router. It's the business. No more USB hassles!
Bobski
I tried one of those hubs, and had the same problems. :unsure:
Got a refund , then hunted round for a voucher to use on an internet site. Managed to get a 7 port USB hub (with mains adpt) for bout 15 GBP.
Works fine. :hocus-pokus:
Gamesound
Go into your bios, turn off the IR (unless you really use it!) and make sure that the usb function is set to all (not just mouse etc).
are you getting one or 2 green lights on the modem?... (one for power, one for trained)
if your not getting the trained light, try re installing the bt comedy junk installer and see if it finds the modem.
what os?.... if win2k / xp right click on my computer and go to devices.... is there an exclamation mark on one of the devices? if so remove it and reinstall the modem.
If this doesnt work, find a big window and throw the laptop out the window .... doenst fix it but makes you feel better! :)
Geoffers
I take it the modem works fine plugged directly into the laptop USB? If so, it's fairly conclusive that it's the hub.
You're right on the limits of the hub even with just the modem plugged in so I doubt it will work. Can you borrow a powered hub at all?
Div
I concurr with the other Geoffers and the other guys; it's almost certainly a power issue, which will only be resolved by getting a powered hub.
HTH,
Div.
andy200sport
Thanks for the replies guys, i've been trying all your suggestions but to no avail. The hub is a self powered one and the modem works fine when plugged straight into the laptop usb port.
When i try plugging the modem into the hub, the laptop sees the hub and powers up the modem (power light on but no line light) but it says the modem is not responding.
I'm on the verge of giving up and following gamesounds suggestion of finding a big window to throw the laptop and the hub through!!! All i want to be able to do is use my usb optical mouse at the same time as the modem!!!!
Andy
ricky_is200
When you say self powered hub do you mean it has its own power and plugs into the mains? If it doesn't thats the type you need.
My cordless optical mouse came with an adapter to convert from the standard USB connecton to the PS2 type. I tried USB first and found when I tried scanning something on my USB scanner the mouse would freeze! So I switched it to using the old mouse port and everything works fine.
andy200sport
Yep, powered hub that plugs into the mains, thing is though the modem appears to be powered up just not communicating with the laptop, anyways, I've given up with it for now, going to get a ps2 adaptor for the mouse instead.
Cheers for the replies people.
Geoffers
Just had another thought - does the laptop have a via chipset? I've had loads of problems with USB hubs and via chipsets. Doesn't seem specific on devices - some work, some don't. I think it's data rate issues.
Updated Via chipset drivers does the trick.
andy200sport
Geoffers, It's got a SIS chipset, would it be worth trying new drivers?
Andy
Full Colour Version: Computer Help Needed
