QUOTE(hyperman @ May 14 2008, 02:48 PM)
That was my first Idea as well, but I was wondering if the welds wouldn't snap under the pressure of the torque.
How much torque does your engine produce?
Your standard prop-shaft is welded anyway. I got mine done by Hoy Engineering in N.Ireland. They cut it, welded it and balanced it. I have never heard of any of their props failing and I have never felt any vibration at all from mine. I told the guy I was going to be running around 600bhp and he said it would have no problem at all handling that power.
If it is done professionally it will be fine. It is not something you wanna take a chance on either because if it snaps it could cut right through the fuel line and brake lines which are directly beside it
