Full Version: Unusual Is200 Ventillation Problem
Lexus Owners Club > General Lexus Forums > Lexus General Maintenance
Dover6Juliet
Hi all..hope you can help. I rather stupidly managed to drop a vanilla pod into the right air vent on the centre console, which has ended up in the tubing inside. The car had a smell of vanilla whenever i turned the fans on but now its starting to get a little foul. Does anybody know how to get into the venting to get this pod out...is it easy to open the centre console up to get into this area? Any other ideas how I remove this thing!
Steve_D
Hello there, the centre console with vents is easy removed - only two screws!, click the link below which will instruct you how to remove that centre panel smile.gif
Click
Dover6Juliet
QUOTE(durrantie @ May 25 2008, 08:11 PM) *
Click
Thanks a lot...seems quite ok...off hand do you know if thre is enough space to put something down the air shaft to weed this pod out. I guess it has gone deep inside...
Are you sure its gone right down?
I'm sure theres some netting behind vents to stop that happening. May be wrong though
Steve_D
You should get your fingers down to an extent otherwise you could always buy one of those grabbing tools from B&Q etc.
Dego
Why not use a vacuum cleaner? You could use a plastic bag and some tape to make a seal over the vent pipe, and then tape the bag around the vacuum tube. Might work???
Dover6Juliet
QUOTE(Dego @ May 25 2008, 09:07 PM) *
Interesting....for sure...any of you guys know where that air shaft actually goes....does it end up with a link to the air blowers by the legs at the bottom...maybe I can get it out from there...
Kiriyama
Click
Not sure what spec that guide was based on but when I came to do the GROM install, there was no need to take ANY screws out at that point. Just grab hold of that section of the centre console (I tipped the vents back, shoved my thumbs in and gripped the section above them with my fingers) and pull towards you, it just comes away. The 2 screws beneath the felt pad don't seem to serve any purpose other than to hold the pad in place!
See:
I have a standard spec IS200 Sport (1999 - V)
QUOTE(Dover6Juliet @ May 25 2008, 07:57 PM) *
........I rather stupidly managed to drop a vanilla pod into the right air vent on the centre console
Sorry but am I the only person to have thought huh.gif why would you have a vanilla pod anywhere in the car in the first place,
let alone allow it to go down inside the vent ? ohmy.gif It didn't get down there on its own surely, or fall down there as it would have to
I looked the other day and just behind the vents is a mesh anyway so once you pul the top vents off it shouldnt have gone any further than that anyway.
Geoffers
Stavs right - you can just about make out mesh covering the vents so you should be able to reach in. Hopefully its not started to decompose and broken down a bit so bits have got through.
I've noticed that on some they are screwed in, others just pull off.
Purvesh
QUOTE(DJ Wozza @ Jun 3 2008, 06:31 PM) *
My advice would be next time just get a Vanilla Magic Tree from the pound shop & don't be so tight.
Now you have the reply/pics to sort your problem biggrin.gif What was you really doing with the vanilla pod icon14.gif
Kiriyama
QUOTE(DJ Wozza @ Jun 3 2008, 09:18 PM) *
Geoffers
Dover6Juliet
Guys, thanks for all your help on this....plan to open this up now that I have time!
Well, I had the pod in my car as I was giving it to someone as a gift (fan of ice creams). Anyway, that person told me to just place the pod itself with my hand in front of the vent and turn the fan on....so as to get a nice wiff. I did so but out of some tragedy I tried to balance the stick on the vent. A daft act indeed and it went in!!!
So that's story folks...I will let you know how it looks when I get it out (if I do!)
Thanks again folks...
Pardon the jokes,
following the steps advised above you should get it out no probs matey.
Dover6Juliet
Hi all....got the vanilla pod out!!! took a few minutes - thanks for all your help. I still have the smell in the car though and it is the bacteria in the washer water it seems....will try to flush it out and use the baby Milton stuff failing that. Thanks a lot! Pictures attached of the item!
