QUOTE(Scarlet Pimpernell @ Jul 29 2008, 01:58 PM)
QUOTE(Roonaldo @ Jul 29 2008, 10:57 AM)
I'm just about to get some quotes for new tyres. 18" Lexus rims F 225/40/18 R 255/40/18.
Its between Toyo T1-R which are available in the sizes above.
Or the Goodyear Eagle F1 Asymmetric which is available in 225/40/18 but NOT in 255/40/18, although they do 255/45/18.
My questions are, which tyre would be better in your opinion?
Secondly, Would 255/45/18 be OK for the rears? If not which sizes are closest to 255/40/18?
Thanks guys,
I thought you had to stick to the recommended sizes only, as the circumeference will change and so will your spedo accuracy, trip computer etc, and you could find yourself inadvertantly breaking the speed limit!!
255/45 will mean that the circumference will increase, therefore effectively changing the "gearing" and final drive too. By what percentage I don't know. You probably need to get that slide rule and Pythagoras's Theorem books out
EDIT in this case, could you not be creating a situation where you are going faster than the speedo says (thereby effectively under reading)?
Here's a comparison...original fitting and speedometer calibration shown in bold for front and rear.
FrontTyre code Diameter Circumference Difference
265/30 R18 616 mm 1935 mm -3.3 %
225/35 R18 615 mm 1932 mm -3.53 %
235/35 R18 622 mm 1954 mm -2.43 %
245/35 R18 629 mm 1976 mm -1.33 %
255/35 R18 636 mm 1998 mm -0.24 %
265/35 R18 643 mm 2020 mm +0.86 %
225/40 R18 637 mm 2001 mm 0 %
235/40 R18 645 mm 2026 mm +1.26 %
245/40 R18 653 mm 2051 mm + 2.51 %
255/40 R18 661 mm 2077 mm +3.77 %
225/45 R18 660 mm 2073 mm +3.53 %
RearTyre code Diameter Circumference Difference
255/35 R18 636 mm 1998 mm -3.86 %
265/35 R18 643 mm 2020 mm -2.8 %
275/35 R18 650 mm 2042 mm -1.74 %
285/35 R18 657 mm 2064 mm -0.68 %
225/40 R18 637 mm 2001 mm -3.63 %
235/40 R18 645 mm 2026 mm -2.42 %
245/40 R18 653 mm 2051 mm -1.21 %
255/40 R18 661 mm 2077 mm 0 %265/40 R18 669 mm 2102 mm +1.21 %
275/40 R18 677 mm 2127 mm +2.42 %
285/40 R18 685 mm 2152 mm +3.63 %
225/45 R18 660 mm 2073 mm -0.23 %
235/45 R18 669 mm 2102 mm +1.13 %
245/45 R18 678 mm 2130 mm +2.5 %
255/45 R18 687 mm 2158 mm 3.86 %
225/50 R18 682 mm 2143 mm 3.18 %
