lexus2000
May 30 2008, 11:36 AM
can anyone help my is200 handbrake light stays on could it be the switch or has anyone had this prob before
aaronabbott
May 30 2008, 11:38 AM
check your break light bulbs,its usually the case well it was with mine
lexus2000
May 30 2008, 11:45 AM
QUOTE(aaronabbott @ May 30 2008, 11:38 AM)
cheers will try that hope that is the prob
May 30 2008, 12:41 PM
It def is one of your brake lights will be out. Start with the high brake light, thats normally the culprit.
To change it, push the shelf down and pop the brake light up.
lexus2000
May 31 2008, 06:25 PM
cheers that was the problem
84Stoney
Jun 2 2008, 02:54 PM
QUOTE(sparkystav @ May 30 2008, 01:41 PM)
Is it that easy! I took my seats, pillars and shelf out!
Should have though really shouldn't I!
Rich OB
Oct 10 2008, 07:05 PM
Hello everyone! Didn't want to start a new thread so thought i'd post here!
I now have this problem which has just started a few days ago!
Hanbrake light stays on all the time, well most of the time. I've checked all the bulbs and all are working fine?
What else could it be? Anything to do with brake pad wear etc?
It is due for service and MoT next month so don't really want to fork out.
rig-pig
Oct 11 2008, 10:09 AM
check you brake fluid level m8 it might be low
wegiel
Oct 12 2008, 07:53 PM
yup, probably the brake fluid level is below min
Rich OB
Oct 12 2008, 10:12 PM
I'll have to have a check on that then! Strange as i don't really use it that much, only done 4k in last year!
I'll post back if it is or isn't. Thanks guys.
Steviewevie
Oct 14 2008, 07:35 AM
I think that another reason for the light staying on is if your brake pads are low. There are quite a few things that can keep this light on, as you can see.
johnboy
Oct 14 2008, 06:58 PM
The brake pads havent got sensors on them to tell you they are low, the brake fluid level will drop as they wear, causing the warning light to come on.
click here.
